Cam Gear Cover Issue
Old Feb 27, 2006 | 11:57 AM
EVOlution561's Avatar
I recently installed AEM cam gears and now the stock cam gear cover does not fit. I have searched and found out that I can cut the the stock cover to make it fit so the AEM gears won't grind on it. Does anyone know how to do this? If so can you please explain to me? Pictures would be great. Thanks
Old Feb 27, 2006 | 06:22 PM
Has anyone else ran into this problem?
Old Feb 28, 2006 | 01:58 AM
Jakeg97's Avatar
what evo do you own? evo8 or 9?
https://www.evolutionm.net/forums/sh...d.php?t=151775
Old Feb 28, 2006 | 08:26 AM
EVOlutionary's Avatar
Take one of your stock gears. Lay in in your cover lined up with the cicular ribs. All of the ribbing that it covers up needs to be cut or ground down. Very simple procedure with a dremel cut off wheel.
EVOlutionary
Old Feb 28, 2006 | 01:50 PM
titaniumkingpin's Avatar
EVOlutionary
I did the same exact thing when i installed my fidanza gears. Take down all the ribs that come in contact with the gear and your all good.
Old Mar 1, 2006 | 10:03 PM
I have the 8
Old Mar 2, 2006 | 01:48 AM
Jakeg97's Avatar
I have the 8
get a dremel kit at walmart and it will come with a grinding tool. and just take your time
Old Mar 2, 2006 | 03:56 AM
EVO8LTW's Avatar
I clearance my cover for AEM gears using a straight edge razor blade. You don't need a Dremel. To verify clearance, put a light coat of spray paint on the cover, run the car a very short amount of time, and then take off the cover and check the paint to make sure that none of it got scraped off by the gears.
talentsearch301
Jun 11, 2017 08:42 AM
liass44
11
Nov 18, 2016 07:05 AM
bayrider
Jun 3, 2008 09:12 PM
hbruce16
May 19, 2005 04:16 PM
RalliArtEvoVIII
Mar 5, 2005 08:44 PM
