Forge RS setting at 22 psi?
Old Mar 4, 2006 | 09:11 AM
lbcevo's Avatar
Where I should set the adjustment knob/spring on my Forge RS to hold 22 psi on 91 octane?
If I start BEFORE the first click, how many clicks do people recommend for 22 psi?
TIA
Old Mar 4, 2006 | 09:16 AM
BBYBruno's Avatar
I did 6-7 clicks for 21-22psi.
Old Mar 4, 2006 | 09:17 AM
DsmAwdTurbo's Avatar
What spring comes in the RS from the mfg? I need to know because I just rcvd mine and thought that there were 3 springs with it :-\
Old Mar 4, 2006 | 09:18 AM
Warrtalon's Avatar
The RS is the BOV. You will have to test it until you get it to where it holds boost as well as possible without causing you too much compressor surge. You have to adjust it until you get it right.
There are no springs with the BOV. It's fully adjustable. Are you guys getting the RS mixed up with the UNOS MBC?
Old Mar 4, 2006 | 09:22 AM
EvoTio's Avatar
The RS is adjustable with a fixed spring. Mine came with no extra springs.
Old Mar 4, 2006 | 09:50 AM
lbcevo's Avatar
Thanks for the feedback! I'll try 6 clicks and go from there.
Old Mar 5, 2006 | 07:27 AM
AfireINSIDE's Avatar
Now do you all mean to begin at full soft, then turn 6-7 clicks or 6-7 full turns?!?!? thanks
Old Mar 5, 2006 | 08:38 AM
Warrtalon's Avatar
You have to find out on your own. It's different on every car, especially yours with a different turbo.
Old Mar 5, 2006 | 08:45 AM
EnJaNir's Avatar
Well after searching through post after post, I found some people had adjusted to nearly 20 positve clicks where others had only set 4. I found that since most had it set closer to 20 I would try that. I do not have a boost gauge so I couldnt get a readings but it drove fine like that. I did notice that during highway driving with partial throttle in 5th gear the car would feel as if it wanted to surge. I dont know exactly how to describe it. I have recently readjusted it to 11 clicks and it seems to be much better but I havent been able to get it to highway speeds yet as I change it yestreday.
Old Mar 5, 2006 | 08:50 AM
Warrtalon's Avatar
You have an aftermarket BOV but no boost gauge? I think I'm going to be ill....
Old Mar 5, 2006 | 09:15 AM
BBYBruno's Avatar
I went to full soft, then I did a full 6-7 turns.
Old Mar 5, 2006 | 01:45 PM
scott88vr6's Avatar
I have 8 full turns or 24 clicks
gman88
Jan 19, 2011 12:13 PM
beemerfreak
24
Nov 20, 2008 03:16 PM
PEARLEVOIXMR
30
May 16, 2007 06:24 PM
TonyG
18
Apr 2, 2007 09:59 AM
jxn evo 8
15
Apr 16, 2006 07:34 AM
