BOV Question
Old Mar 4, 2006 | 04:05 PM
twinscrewed's Avatar
BOV Question
Ok, this is NOT one of those "which BOV is best" threads. Sorry to disappoint.
Anyway, my bov is now VTA with the addition of an EMS. While the car is ideling, its blowing off some air. I tried tightening the spring (APS BOV) and its still leaking the same amount of air. This is my first VTA bov, so i'm not sure if its supposed to be doing this or not.
Anyone know if this is normal or not? It holds boost fine under WOT so i know the spring is tight enough. I just want to be certain this is normal before I drive the car anymore.
Thanks
Old Mar 4, 2006 | 04:20 PM
Eclipsed Evo's Avatar
It should not leak.
Old Mar 4, 2006 | 06:32 PM
I didn't think so. But I don't understand how it holds 25 psi to redline if it leaks at idle.
Old Mar 4, 2006 | 06:46 PM
race17k's Avatar
sounds like the spring could be too tight or too stiff of a spring maybe? If not could be a defective unit!
Old Mar 5, 2006 | 09:50 AM
nicksalerno80's Avatar
I had an APS on my car and I did not have the problem of it leaking at idle, it would blow off early sometimes. Now when you say VTA, is it blocked from the intake recirc completely because the APS, mine was, is a dual port BOV. Also with mine, I only got to to each the atmosphere port once, not using it anymore.
Old Mar 5, 2006 | 10:26 AM
too tight? I guess I have nothing to lose if I go loosen it up and see what happens. If it doesn't work, i'll pull it apart to see if anything is obstructing the valve from closing all the way. And if that doesn't fix it i'm going to pick up an SSQV tomorrow.
Old Mar 5, 2006 | 10:54 AM
FASTEVO8's Avatar
How new is the BOV? If that does not work you should send it back and get another one.
Old Mar 5, 2006 | 12:33 PM
SpeedLab_EVO's Avatar
all bov's leak at idle to keep from building boost. i found that out by having the same "problem". i had to call hks to find.
Old Mar 5, 2006 | 12:47 PM
SSKILLA's Avatar
yeah mine leaks at idle too and i can hear a slight whistle on decel cause of the high vaccum but it hold boost like a champ till 7800 rpm
Old Mar 5, 2006 | 02:50 PM
nutsack's Avatar
all BOV's are "open" when seeing vacuum.
Old Mar 5, 2006 | 02:53 PM
SSKILLA's Avatar
yup the small whistling on decel sounds like a have a bird trapped under my hood....lol gets anoying when slowing down but the whoosh is sweet
Boost3dxEvO
Jul 17, 2007 02:08 PM
M3this
27
Oct 20, 2006 05:54 PM
RalliArtEvoVIII
May 8, 2005 07:15 PM
RalliArtEvoVIII
Mar 22, 2005 04:35 PM
