Holding boost to redline
Old Mar 6, 2006 | 06:11 AM
housedj's Avatar
yeah get the walbro FP. was the restricter pill removed out of the boost line when you installed the boost controller?? Ecutek seems to be all over the place when u remove the pill...
Old Mar 6, 2006 | 10:13 AM
talontid's Avatar
whats not smart about running 23-24 lbs on pump... ??? The car is tuned for it... Sean Ivey said it ws fine and I trust im alot more than half of the people on here
Old Mar 6, 2006 | 02:21 PM
bigjhoney's Avatar
Originally Posted by SSKILLA
thats not smart to run 24lbs on pump gas
It would spike there, I would never let it hold 24 to redline, 23 tops. Now that its getting warmer out its not spiking as much, boost is much more precise. Im on 93 octane, and I actually turned the boost down a pound since I was tuned.
Old Mar 6, 2006 | 05:58 PM
Joey B's Avatar
Veteran: Air Force
If you don't want as much boost spike, go with running the MBC from turbo to the wastegate. I've had it the other way too - BOV line to wastegate and you get more of a spike.
I've posted a few times on questions about trying to hold boost to redline and never found an answer to replacing the wastegate actuator or not. The only thing I could find was a post that Mike@Forge (who sells the actuators) stated that some of his customers have reported that the Forge actuator seemed to eliminate the boost taper. Other than that, I haven't found jack on answering that question. I believe most replace their turbos before that or just plain put up with it.
Love to see a factual answer but no such luck. I'd be interested to find out something that had some backing to it other than..."that's just the way it is"
pwnstar
11
Nov 20, 2011 12:07 AM
hova00
Nov 5, 2006 11:21 PM
Soon2BEVO
50
Feb 17, 2006 07:08 PM
xstang
22
Oct 27, 2004 10:26 AM
Evolocity
Jan 22, 2004 01:57 PM
