20G or 16G ?????
Originally Posted by Nez136
and you know this from experiance?
20G:
http://www.ztechz.net/sitebuildercon...6h-20g-cfm.gif
Stock 03/04 twin scroll:
http://www.stealth316.com/images/td05hr-16g6-cfm.gif
Originally Posted by sonicnofadz
Yes, however you don't need to try the turbo to know its performance numbers lol. They have these things called compressor maps:
20G:
20G:
Edit* you don't have to be a smart *** in your posts, if thats the way your going to be than you can join all the other jackass's on this forum on my ignore list
to u maybe, but with stage 4 and the buschur 20g-9-5 u can get 375whp on pump gas. lets see the 16g do that consistantly without alky.
The small difference in performance is not worth the cost.
It HAS done it without alky (race gas) =)
I'd go with a 20g-9 TME based (w/ the 9 compressor housing). That way you gain the spool up advantage of the lighter turbine plus the FP wheel which makes a big difference in sustaining boost at high rpms. Its also a good turbo to move forward with and with a proper setup is 400-420whp capable with a ton of power under the curve.
This is for the people who don't want to spend $$$ on turbo kit upgrade, not including some kind of engine managment, want something that is just an easy bolt on as gives them reasonable power w/o worry of anything else.
That is personal opinion which goes further into debate with other mods. Ti exhaust with cat delete and down pipe....$800. about 25whp depending on mods. that is just one example of money vs power. I see in your sig that you have the EDFC which, if im not mistaking, cost a pretty penny, now i can't justify the cost if it only takes a couple minutes to adjust the damper manually.
on a side note, i love my 20g to death, but i want the maximum amount of power, i ordered a Buschur GT3065 kit and my 20g-9-5 is going up for sale.
PM me for details or with offers
Originally Posted by atlvalet
What is a GT3065?
Edit* Fixed
Question for you all with a evo9 or 20G-9 turbos.
Which of the following is the correct code or part number for the evo 9 compressor housing. Is there a way to tell by the stamping on the side?
#1 ******-16G6-***/49378-01520
#2 ******-16G6C-***/49378-01580
#3 *******-16G6mC-***/49378-01570
my contribution.https://www.evolutionm.net/forums/sh...d.php?t=177969
Originally Posted by Nad1370
Td05hr-16g6c-10.5t
49378-01580
Td05hr-16g6c-10.5t
49378-01580
From reading all 90 of the threads I also found if it has a TD05HRA in the part number thats the Titanium wheel originally. Not that it makes a difference since the original wheel was replaced, but in case someone wanted to know what the A was for.
adrynalinjunkie
60
Apr 9, 2008 09:00 AM
