Custom made engine harness plugs needed.
Old Mar 6, 2006 | 08:09 PM
bolsen's Avatar
Someone in here made custom plug connectors for their aftermarket ECU to fit the stock harness. Does anyone know who that was? I need 3 of them made.
Old Mar 6, 2006 | 08:30 PM
TrinaBabe's Avatar
Yes Malibujack did I believe. Ask him about it... he can help you.
Old Mar 6, 2006 | 08:43 PM
bolsen's Avatar
THAT'S who it was! I thought I remembered it being a guru...
Old Mar 6, 2006 | 09:22 PM
mchuang's Avatar
You can also get an ecu from a 2.0 liter obd2 gs or gst, or a hyundai elantra with 2.0 4g63 motor or the kia that has the motor and take 1 piece from the ecu and cut the harness and solder together. I have a gen 2 ecu off a gst and it plugs right in to my evo, probably diff pin outs, but all connectors do plug right in perfect
Old Mar 6, 2006 | 09:25 PM
bolsen's Avatar
I'm trying not to cut the stock harness
Old Mar 6, 2006 | 10:24 PM
EFIxMR's Avatar
Here's something i made that fits what you are talking about.
Old Mar 7, 2006 | 07:04 AM
bolsen's Avatar
Umm, I'm not sure what I'm looking at? Did you make the plugs or are you implying I should be running the MoTec?
Old Mar 7, 2006 | 11:21 AM
EFIxMR's Avatar
yes i fabbed up that adapter harness. it allows my aftermarket ecu to plug into the stock wireharness.
Old Mar 7, 2006 | 11:41 AM
TrinaBabe's Avatar
They also sell jump harnesses.. you could buy one of those and cut off one end of it and then put your own harness in. Whatever ECU you got with should come with at least a pigtail or its own harness coming out then just professionally connect each wire with its corresponding stock wire. Would take some time but once done it would be perfect and could be disconnected quickly.
Old Mar 7, 2006 | 11:50 AM
kcevo's Avatar
Are you looking for the 4 plugs that plug into the ECU or the other end that is part of the ECU?
Old Mar 7, 2006 | 11:58 AM
bolsen's Avatar
Here's what I'm looking for. The new MAP sensor has a pigtail. The pigtail that connects into the stock wiring harness doesn't have an end on it. Instead of cutting into the stock harness I want to get a custom connector made where I can choose which pins to use. This custom made connector will conect into the stock harness plug.
Malibujack can make them, but he won't have time till spring, so I'll have to contact a company here in MKE.
Old Mar 7, 2006 | 12:04 PM
kcevo's Avatar
Ahh, i know what connector you are looking for. If you want to keep the connector in the car, then I would just tear back some of the sheathing on each wire and solder in your pigtail for the MAP sensor. You could run each wire thru the fire wall and re-pin them in the AEM, but you have to make sure you have a spare 5volt output and sensor ground as the MDP sensor wiring that I am talking about using shares a 5volt and ground reference with other engine sensors.
Old Mar 7, 2006 | 12:08 PM
bolsen's Avatar
I was under the impression that I could use the stock MDP sensor wiring? Hmmm.
Old Mar 7, 2006 | 12:16 PM
kcevo's Avatar
You can, but what you are asking is that you don't want to cut the MDP sensor connector off of the harness nor splice into it. Getting the other end of the connector in a kit to re-pin, by itself will be very hard to find, maybe you could find them but you will have to buy in bulk. Easiest way is to just splice the 3 wires on the map sensor to the 3 wires for the MDP sensor.
Old Mar 7, 2006 | 02:13 PM
TrinaBabe's Avatar
Cut the connector off the MDP sensor and solder it to the new sensor pigtail... now plug it in.
If you want the stock sensor for some reason I got two with the stock pigtail in tact
kaj
For Sale - Part Outs
Jun 3, 2016 08:10 AM
sickness06
Aug 15, 2015 09:03 AM
Dan@Assaultech
55
May 29, 2012 09:24 AM
DuffmasterFresh
Jan 20, 2011 05:11 AM
downshift411
Feb 19, 2008 06:22 AM
