open loop bov on evo
Old Apr 8, 2003 | 12:00 AM
nine4surfah's Avatar
Will a vpc from hks adjust the air/fuel mix problems when vente to the atmosphere? and is it worth the cost? looks complicated to install too
Old Apr 8, 2003 | 12:37 PM
rt turbo's Avatar
yes, a vpc will stop the idle and every problem with accociated with the mas because it replaces the system with a vien-pressure control unit... hince VPC. its not hard to install, infact, hks makes wire kits directly to plug into certain car's ecu's so there is no splicing. im ganna have to make my own wire kit for the greddy with plugs so i can easily unplug it when going to the dealer.
Old Jul 11, 2003 | 01:03 AM
EvolutionEight's Avatar
what about safc ver 2? will it help the car run fine with vta ?
Old Jul 11, 2003 | 09:56 PM
Incognito's Avatar
Yes, the SAFC2 does have a thing for VTA BOV's. Not sure how to use it, but it's there. Controls the 2 lowest NE points.
Old Jul 12, 2003 | 07:33 AM
BoostedMike's Avatar
Re: Re: open loop bov on evo
Originally posted by Claudius
HKS BOV is known for problems on Evos.
How do you figure? I've got it on my car VTA and it's great!
Old Jul 12, 2003 | 05:27 PM
Shahul X's Avatar
i have it on my car WITH the recirc kit...and its still an issue
-Shahul
Old Jul 12, 2003 | 05:29 PM
Shahul X's Avatar
check it out....
https://www.evolutionm.net/forums/sh...hks+ssbov+pics
I HIGHLY caution using the SSBOV, try the forge,.... and FU(K the sound, its not worth it
-Shahul
Old Jul 12, 2003 | 06:43 PM
bishiboy's Avatar
No need for VTA
I put an HKS Racing Suction kit on my EVO. I hear every breath of the intake including the PSSSSTTT of the BOV (stock). I got it from Boost solutions for $315 and got it in 4 days!!
Old Jul 12, 2003 | 10:12 PM
timzcat's Avatar
For anyone interested, this test was done on a 2G DSM at like 9lbs I think it was.
$300 or so for a valve that doesn't work well on the Evo just doesn't make sense.
The Forge by design works extremely well on the Evo. I have a post on it's operation, etc. And it only like $150. It'll hold boost no problem because it is using boost to keep it shut and you can change the spring if you get to that boost level.
dvd_mi
18
Jan 29, 2011 03:25 PM
ArchieBabes
Feb 23, 2006 08:42 AM
GT7evo
10
Jul 28, 2005 09:47 AM
rt turbo
14
Feb 13, 2005 03:42 PM
rt turbo
Jan 23, 2003 09:13 AM
