boost problems, help!!!!!!
Old Mar 9, 2006 | 05:48 AM
EVIL_EVO_VIII's Avatar
I installed the megan o2 housing 2 weeks ago and ever since then, im having some really weird boost problems. First, im getting boost creep and only when its cold out, it doenst do it during warm weather. Second,my boost levels keep changing constantly w/o me even touching the mbc. Third, i get out of the car to adjust the boost on the mbc, and it doenst go down, then i get out again, adjust it and again it wont go down. I have adjusted it like 3-4 times, then when i do a wot pull, the boost is too low. I go and turn up again less this time and the boost goes high again. The other night i hit fuel cut and i still have the stock bov, the car kept giving me boost crep in 4th gear!! I just cant seem to set my boost normally like i used to before. The weird problem is that im getting different boost levels at wot passes w/o adjusting the boost controller. Can anyone help on this?!!!!!!! Is it the mbc?
Old Mar 9, 2006 | 06:06 AM
MANGOOK's Avatar
There is a problem somewhere because I have the megan manifold and 02 housing. When it was installed the boost went up 1PSI but I am not having any creeping at all. I didnt even have to play with my boost controller at all either. I hope you get it figured out and a free bump for any ideas or an answer!
Old Mar 9, 2006 | 06:23 AM
bump for more responses!
Old Mar 9, 2006 | 06:24 AM
Deepseadiver's Avatar
Good luck with your boost problems. Check and check again that you have it hooked up right. I had the same problems you were talking about. I turned out that I hooked it up wrong after I adjusted/rerouted my vacume lines. Also do a boost leak check, and get the JDM BOV. Good luck.
Old Mar 9, 2006 | 06:26 AM
rcheung's Avatar
I also have the megan 02 outlet and exhaust manifold. I didn't experience boost creep either after it was installed. The only thing that changed with the boost was the same thing that happened to mangook, it would boost 2 psi higher at WOT. But reconfiguring my EBC took care of that.
Old Mar 9, 2006 | 06:29 AM
I nver touched or took out the mbc when i did the o2 housing, all i took out was the hotside with the stock o2 housing to do the swap. I dont know what the problem is, its driving me crazy, im holding 1.6-1.5 to redline with the stock bov and even hit fuel cut the other night
Old Mar 9, 2006 | 06:44 AM
kevo's Avatar
EVIL_EVO_VIII, I did a search on boost creeping problem and found some post about people having the exact same problem when they swap the o2 housing to aftermarket one including myself. I'm going to swap my stock o2 back on since that seems to be the only way to solve the problem. I know a lot of people don't have any boost creep problem with the o2 housing, maybe we just bought a bad batch. I suspected that it could be the wastegate port on our SS housing is not big enough?!
Old Mar 9, 2006 | 06:57 AM
Well, at least im not the only one with this problem. Im gona have to take it off again, since i cant control these boost problems. Ill probl end up selling it
Old Mar 9, 2006 | 08:41 AM
bump for more help!
Old Mar 9, 2006 | 08:49 AM
eve-slow's Avatar
For some reason, some people (including myself) are having creeping issues after installing aftermarket o2 housings. My creep was out of control, flying past 25 psi at about 1/4 throttle. Go back to your stock o2 housing.
Old Mar 9, 2006 | 09:10 AM
So this whole problem seems to be linked to the o2 housing. I thought it could have also be the wga or the mbc, but looks like your having the same issues. Im gona have to take it out and sell it which sucks!
Old Mar 9, 2006 | 10:18 AM
TTP Engineering's Avatar
User install error. None of my customers or myself for that matter have these issues. Evilevo is isolated and have worked with him to improve the condition. Without looking at the car, we are limited on what we can do at this point. TTP did not install his O2 housing.
Eve-slow, you have way too much preload on the WGA arm. That is your problem.
For others, another problem could be that the WGA arn itself can spin around 180* and does not allow the flapper door to open correctly if you put it back on the pin opposite.
Old Mar 9, 2006 | 01:05 PM
mikiblueeyes's Avatar
Meagan does nothin gto do with unstable boost. I can be cause by a pinole in the vac hose, or dirty MBC. I would go to autostore and get new lines and may be swap a MBC with anyone around to see if thats the issue and narrow down the problem. Like been said before the boost would go up by about 1 PSI if all the same remain equal, it would not be erratic.
Old Mar 9, 2006 | 03:44 PM
the weird thing with my issue is that the boost creeps only happen ocassionally, specially in 4th at wot. Hopefuly i can have ttp assist me with this issue
Old Mar 9, 2006 | 03:52 PM
talon2evo's Avatar
This may seem like it's out of left field, but what do you have for your air intake? Stock intake box, or ??
