9.1 Compression and Timing?
Old Mar 12, 2006 | 03:11 PM
lbcevo's Avatar
I just finished breaking in a new 2.3 motor and my compression is now 9.1 (vs. stock 8.8). My AFRs are 10.5-11.0, timing is conservative (4-8 mid, 17 redline), and boost is 20 psi peak but I'm still getting some knock--according to my UTEC.
How much does the higher compression affect timing and knock? I already backed my old timing off 2 degrees where it was knocking but it's still knocking.
TIA
Old Mar 12, 2006 | 05:11 PM
Agent-Smith's Avatar
Starting at 11 and richening to 10.5? Try getting a little bit more fuel in there goto maybe a 10.2 -10.3 in the knocking area.
ALso you are using the knock sensor that came with the utec? If i remember correctly they will not read right off the stock unit.
Old Mar 12, 2006 | 10:22 PM
Widebandphillip's Avatar
Post a log?
Old Mar 12, 2006 | 10:29 PM
scorke's Avatar
Just wondering, where you told to go with a 9.1 to 1 ratio by a tuner or did do this on your own?
Scorke
Old Mar 12, 2006 | 11:02 PM
lbcevo's Avatar
It's an RnR 2.3 and 9.1 is standard on all their motors.
Old Mar 13, 2006 | 04:29 AM
94AWDcoupe's Avatar
Strokers need a good bit less timing. Dont be afraid to keep backing timing down. Small timing numbers are a good thing, less pumping losses.
Live4Redline
Jul 17, 2024 07:09 AM
Seancj
Jul 2, 2015 06:22 AM
def1
Aug 2, 2009 07:51 PM
acamus
Oct 24, 2008 06:22 AM
Kings Fan
Dec 30, 2006 04:22 AM
