Need a AEM map ASAP (35r,1000cc,5bar)
Old Mar 25, 2006 | 05:12 PM
LIFER's Avatar
Well The map I have now will not idle (to rich). I need a map good enough to get me to Buschur so I can have it tuned.
Parts installed
gt35r
built bottom end
ported head
280 cams
1000cc injectors
5 bar map
(see sig)
If you have a similar setup.. please email me your map to brandoncarmean@fuse.net
Old Mar 25, 2006 | 08:18 PM
jmartinez1170's Avatar
have AMS email you one that might charge you a arm and a leg for it but give it a shoot. but most likely there going to want u to bring the car over and that would be the best way to go. or just go to b/racing there in your town i think.
Old Mar 25, 2006 | 08:19 PM
jj_008's Avatar
Parts installed
gt35r
built bottom end
ported head
280 cams
1000cc injectors
5 bar map
(see sig)
Why don't you ask Buschur?
Old Mar 25, 2006 | 08:28 PM
slowevo4me's Avatar
just plug back in the stock ECU and run in limp mode to get there. That's your safest bet.
Old Mar 26, 2006 | 07:23 AM
SwiftEVO's Avatar
Parts installed
gt35r
built bottom end
ported head
280 cams
1000cc injectors
5 bar map
(see sig)
Why dont you just lean it out a bit at idle. Its nots hard to do. Just play around with the fuel map in the table view. Highlight the area where it idles and press - to pull fuel from all the cells.
--Josh
Old Mar 26, 2006 | 07:42 AM
EVO8_PR's Avatar
each vehicle is completely different you should never rely on a map of another car because it has the same setup. If you aren't familiar with tuning the EMS I suggest you pay someone who knows what he's doing. It's better to spend money on a good tune than to have to spend a bigger amount on rebuilding you engine.
Old Mar 26, 2006 | 08:21 AM
IEXCELR8's Avatar
Call Sean Ivey he could help you out with a base map.
Old Mar 26, 2006 | 12:02 PM
platinumspecv's Avatar
Why can't Buschur send you a map if he will be the one tuning it ?
But yea.. Sean will make you a very good map
Old Mar 26, 2006 | 02:57 PM
Smogrunner's Avatar
I'm sure you will be up and running in no time. Be patient.
Old Mar 27, 2006 | 06:06 AM
SwiftEVO's Avatar
What kind of a/f are you running at idle? Send me your map swiftevo@***.net
--Josh
vr4play350
Feb 5, 2014 08:08 PM
MR
36
Mar 27, 2010 10:51 PM
trackstar2885
Dec 2, 2007 09:09 PM
haseeb
14
Oct 12, 2007 02:32 PM
Smurf Rocket
AEM EMS
Jul 15, 2007 03:53 PM
