White Rabbit Peak PSI Flow?
Old Mar 27, 2006 | 08:50 AM
KazzEvo8's Avatar
I'm wondering if anyone's done the numbers and knows where ideal, peak boost is for this turbo. I'm currently running Buschur's Deluxe IC and piping, FP's actuator and 10.5 hotside. I'm running a SOLID 25psi with early spool and no lag with 1-2 gallons of 100 octane mixed into the normal 93 octane diet.
I'd like to know where the point of diminishing returns starts with pressure and temp.
Thanks for any help!
Old Mar 27, 2006 | 08:57 AM
Ted B's Avatar
I recall that we've estimated it will reach choke point around ~10% greater flow than the 16G, which equates to an additional 30whp or so in ultimate potential. As to where this occurs with respect to boost pressure and rpm, that's going to vary somewhat with the particulars of the setup. The more efficient a particular setup is at peak power, the lower the pressure the choke point.
Old Mar 27, 2006 | 08:12 PM
KazzEvo8's Avatar
Well that sure as hell ain't definitive ... *Laughs*
Anyone have WR experience to share about boost pressures, builds, and peak numbers?
Old Mar 27, 2006 | 08:19 PM
13-0's Avatar
But its correct and if your trying to get "ultimate flow numbers" from other users off a message board your playing with fire. If the compressor charts arent published by the turbo man. then you will have to do the old MABT on a dyno.
Old Mar 27, 2006 | 08:31 PM
dryad001's Avatar
From what I was told 27-28psi is the sweet spot. Once the warmer weather comes along and if I still have the turbo I'll push it a little farther. Right now I have it at 25psi and it pulls very nice.
Old Mar 28, 2006 | 05:09 AM
KazzEvo8's Avatar
Thank you for that input.
Old Mar 28, 2006 | 05:12 AM
KazzEvo8's Avatar
Try and post your results. Info on the WR seemed to have dried up a few months ago. Good luck!
weebles
23
Aug 13, 2009 08:50 PM
shangai
Oct 1, 2008 10:49 PM
djsgtrip
Jul 30, 2008 08:37 PM
Jeff_Jeske
Apr 20, 2007 01:30 PM
thatguy
13
Nov 13, 2006 10:13 AM
