Gsc 264/274's are bigger injectors needed?
Old Mar 31, 2006 | 03:09 AM
funnyclub's Avatar
Hey guys will be getting these cams soon. I have a EvoVII with stock turbo:- I have tubalur mani, turbo back exhaust, intake, fuel pump, power fc and boost controller.
Will my stock injectors be okay to run these cams as I would rather get injectors the same time as the cams if needed.
Thanks in advance.
Paul
Old Mar 31, 2006 | 05:39 AM
Ultimate CC's Avatar
no need for injectors
funnyclub's Avatar
Thanks mate
Old Mar 31, 2006 | 06:03 AM
nrcooled's Avatar
It really depends on how much boost you want to run. Do you have anyway of checking your duty cycle? I would be willing to bet that your stock injectors are close to maxed right now (maxed meaning 90%+) at WOT.
I would get some monitoring tools/piggy back so you can get the crutial information about your engine status.
Old Mar 31, 2006 | 06:05 AM
anjapower's Avatar
not needed with stock turbo on pump gas.
Old Mar 31, 2006 | 06:09 AM
Definitely not need on race or alky, my duty cycles are even lower on alky than on pump
Old Mar 31, 2006 | 06:19 AM
funnyclub's Avatar
I will be running pump gas and about 22 psi dropping to 29-21psi.
Old Mar 31, 2006 | 07:21 AM
funnyclub's Avatar
Anyone else.
Old Mar 31, 2006 | 08:25 AM
Soon2BEVO's Avatar
Stock injectors are more than sufficient.
Old Mar 31, 2006 | 09:14 AM
hawjdude's Avatar
I'm running stock injectors on the GSC 272's.
Old Mar 31, 2006 | 10:15 AM
992gnt's Avatar
Certainly can be done on the stock injectors. However, I was seeing 90%+ idc and lowing timing numbers near redline before I put in larger injectors. Now idc stays under 85% and I've got more timing than I know what to do with.
Old Apr 1, 2006 | 04:55 PM
nnorris7413's Avatar
Same with me, and my car is perfectly fine the way it is.
Casey118
Mar 20, 2017 07:33 PM
RSGuy
28
Apr 7, 2011 04:34 PM
bbyevo8u
28
Jul 22, 2009 01:51 PM
chuckbyu
AEM EMS
18
Jan 29, 2009 07:53 AM
evotino
16
Nov 13, 2005 01:57 PM
