ACD Overfill ?
Old Apr 1, 2006 | 01:58 AM
RS2's Avatar
RS2
ACD Overfill ?
A friend of mine who owns an evo is having a strange noise when he accelerates, when I checked out his ACD reservoir which is in the trunk it was way too high, higher than max !!!!
Is this the problem ? does the ACD make some brrrrrrrrrrrrrrrr sounds ?
Note: ACD was flushed last week and refilled.
Old Apr 1, 2006 | 07:54 AM
RS2's Avatar
RS2
bump
Old Apr 1, 2006 | 10:38 AM
althemean's Avatar
how did he get the acd reservoir in the trunk? Did he relocate it all the way back there? If so, for what purpose?
Old Apr 1, 2006 | 10:42 AM
jrsimon27's Avatar
it should be a little bit higher then the max limit line always check the level when you have the car parked the acd in in the trunk althmean
Old Apr 1, 2006 | 10:49 AM
althemean's Avatar
I have an 05....my acd pump is in the engine compartment. The windshield fluid is in the trunk. I can take a pic to prove it.....although I dont see why that would be necessary. What ACD reservoir are we talking about? There is nothing in my trunk for the ACD or am I missing something? My trunk is stripped of all but the side liners right now.
Old Apr 1, 2006 | 10:53 AM
jrsimon27's Avatar
its in the trunk! check the left side of the trunk take off the side liners
Old Apr 1, 2006 | 10:59 AM
althemean's Avatar
Clearly it is not. The empty side compartment is the LH. The one with the reservoir is the RH side and clearly shows the windshield washer fluid. Please explain.
Attached Thumbnails ACD Overfill ?-trunk-001.jpg   ACD Overfill ?-trunk-002.jpg   ACD Overfill ?-trunk-003.jpg   ACD Overfill ?-trunk-004.jpg
Old Apr 1, 2006 | 11:09 AM
Danny23's Avatar
the acd res. is on the drivers side where the intercooler spray res. used to be.was it low and he filled it up because after driving the acd fluid will be low, down to the low mark on the res. after it sits it comes back up to full, this is normal. maybe he noticed it was low after driving the car and filled it up and then after sitting it came back up like its supposed to
Old Apr 1, 2006 | 11:11 AM
althemean's Avatar
^^thats what I am saying....the ACD res and pump is under the hood...not the trunk. Maybe JDM models are different?
Old Apr 1, 2006 | 03:34 PM
jrsimon27's Avatar
yep my car is different i have it in my trunk left side
Old Apr 1, 2006 | 03:41 PM
Bimmubishi's Avatar
AYC or ACD? I think that this might be the clarification.
Old Apr 1, 2006 | 06:32 PM
RS2's Avatar
RS2
The Evo 8 is an RS (JDM) so ACD Res is in the trunk
Actually he told me some mechanic just filled it for him and beyond the Max line. so could the overfilling be the problem ?
Like this
Old Apr 1, 2006 | 07:25 PM
gunzo's Avatar
the trunk reservoir is AYC topup..
depending on how much you use the ayc.. the fluid will fluctuate up and down.. you should never need to top up unless its leaking..
Old Apr 1, 2006 | 07:28 PM
RS2's Avatar
RS2
E VIII RS JDM comes with ACD *ONLY*
So AYC has nothing to do with this
tauro91
Jun 29, 2017 02:14 PM
Devesh Budhram
Dec 30, 2016 03:21 PM
hktrigguy
Sep 6, 2016 10:35 AM
lordofwar
27
Feb 24, 2008 12:12 AM
jrsimon27
Mar 19, 2006 04:45 PM
