Will a 2.3 stroker pass emmisions?
Old Apr 9, 2006 | 10:00 AM
Atlmethevo's Avatar
I am thinking about doing the 2.3l stroker but I would also like to know if you run the stock ecu to pass the obd2 test will it throw a cel? Has anyone ran a 2.3 with a flash also?
Thanks again
Old Apr 9, 2006 | 10:02 AM
Thugline's Avatar
I don't think so bro!
Old Apr 9, 2006 | 10:04 AM
EvoTio's Avatar
I don't see why not. As long as the cams you're running are not too agressive, you should be fine.
Old Apr 9, 2006 | 11:55 AM
nrcooled's Avatar
It will pass but you will need to get flashed to get rid of the P024x overboost and also you may throw codes for being catless/highflow cat. It's very possible but you just need to plan ahead.
Old Apr 9, 2006 | 08:11 PM
Ted B's Avatar
It should pass if:
(1) you have a catalytic converter
(2) you have factory cams, or your cams are timed to smoothen the idle and make the engine run clean for the test.
EVO(boss)
Oct 13, 2009 09:46 AM
richysevo8
100
Mar 2, 2008 08:19 AM
sterdyevo
12
Dec 8, 2007 12:08 PM
evo_il8
14
Jul 30, 2005 11:44 PM
evo8silver
10
May 17, 2005 05:26 PM
