Fastest spooling pump gas (big) turbo?
Old Apr 9, 2006 | 07:48 PM
Fast Frank's Avatar
Where do i go from the "white rabbit" on pump gas? Using 94 octane, I want it to spool as close to stock, (that's why I went w/ the white rabbit) a 35R is for sure going 2 b 2 much-Thinking of a 30xx series?
Then the next ? is how much more am I going to get using just pump gas? & is it worth it?
Thanks!
Old Apr 9, 2006 | 08:14 PM
Tpayne84's Avatar
i would go buschur 20g-9 or ams 50 trim. Both make pretty nice power with good spool. How much WHP are you wanting?
Old Apr 9, 2006 | 08:29 PM
Fast Frank's Avatar
I would like 400 whp, but don't want to blow another motor because of methanol messing up & still would like to run pump gas-
Yes have my cake & drive it too!
Old Apr 9, 2006 | 08:32 PM
blkAMSevo8's Avatar
dude lag is overrated once again, my 35r gets full boost by 3800 rpm on a 2.0.
Old Apr 9, 2006 | 08:36 PM
sleet's Avatar
You got any logs or anything? How much boost you running? How do you get it to spool that early?
Old Apr 9, 2006 | 08:38 PM
blkAMSevo8's Avatar
right now running 33psi, and again, lag is overrated, ask any 35r owner.
Old Apr 9, 2006 | 08:43 PM
PPI's Avatar
PPI
I would love to see a log (assuming AEM) of 33psi by 3800 rpm and what gear it was done in.....
Old Apr 9, 2006 | 08:48 PM
blkAMSevo8's Avatar
Go take a ride in a 35r car, that will be a good log for you. And of course not 33psi at 3800, but damn close.
Old Apr 9, 2006 | 08:50 PM
blkAMSevo8's Avatar
https://www.evolutionm.net/forums/sh...hreadid=189481
Old Apr 9, 2006 | 09:06 PM
Fast Frank's Avatar
35R w/ pump gas could only make how much boost & then how much lag?
Old Apr 9, 2006 | 09:08 PM
sleet's Avatar
33PSI @ 3800RPM? Where do you build 22PSI at?
Old Apr 9, 2006 | 09:11 PM
Tpayne84's Avatar
A 35r is an awful turbo for pump gas and stock motor.
for 400whp on pump gas i would get a 50 trim or 3037r.. but if you were to add alky you would be getting about another 50WHP safely. We can make over 500whp on our stock motors safely.
Old Apr 9, 2006 | 09:21 PM
KevinD's Avatar
haha, if thats the dyno plot of your car, youre not making full boost until well after 5k rpm.
Old Apr 9, 2006 | 09:25 PM
jj_008's Avatar
+1
Old Apr 9, 2006 | 09:28 PM
fromWRXtoEVO's Avatar
so a 35R gets full boost at 3800 rpms uh?
Carlos
