View Poll Results: Would You be interested
Definately
82
71.93%
Maybe, Depending on Cost
24
21.05%
No, i want a tubular manifold so i can look cool.
7.02%
Voters: 114. You may not vote on this poll
Forced Performance Petition
Old Apr 12, 2006 | 01:32 PM
Juiced's Avatar
i want to get a petition together to see if we can't convince FP to design a turbine housing that bolts up to the Twin Scroll Stock Evo manifold with there 44mm wastegate port .
From the testing i've done the ported and coated evo manifold can floe enough to support at gt35 at about 34psi.
If they were to do this they would corner the market for the ultimate direct replacement turbo.
Who's with me lets get this going.
NOTE: I KNOW THE GT TURBO'S ARE NOT TWIN SCROLL THE DESIGN OF THE INLET ONLY CREATES A MINOR RESTRICTION OF LESS THAN 1CFM. IT WOULD BE A THERE CUSTOM TURBINE HOUSING WITH A TWIN SCROLL FLANGE.
Old Apr 12, 2006 | 01:37 PM
travman's Avatar
I would love the option to bolt up a garrett 50 trim......doubt it ever happens
rallysport04's Avatar
I would deffently be intrested in a twin scroll flanged garret gt turbo.
Old Apr 12, 2006 | 01:43 PM
joeymia's Avatar
i don't understand why no one has done it yet
Old Apr 12, 2006 | 01:44 PM
Juiced's Avatar
Few companies have the resources and ability to do the design, Good thing FP already has the design all they have to is change the flange.
Old Apr 12, 2006 | 01:45 PM
SuperHatch's Avatar
Cost.... that's why no one has done it yet.
The tolerances needed between the turbine housing and the turbine wheel are very tight. Get it wrong and it'll work like crap. Just look at the ATP kits.
Old Apr 12, 2006 | 01:48 PM
SSKILLA's Avatar
i want a damn 50 trim bolt on..........i can only dream
wow that would be awsome though
Old Apr 12, 2006 | 01:49 PM
travman's Avatar
I believe Precision turbo has garrett turbos that bolt to the eclipse manifolds? My friend with the 1G is running a 50 trim and I thought it bolted to his stock manifold, could be wrong.... http://www.precisionturbo.net/turboc...tegory_id=3024
If so why couldnt someone make to work with the evo, boy would that relieve alot of headaches! but yea im sure cost has a lot to do with it, r&d time, casting, etc...
Old Apr 12, 2006 | 01:55 PM
travman's Avatar
btw I am correct they do have the mitsu turbine housing that mates to the garrett center section.....so why not for the evo?
Old Apr 12, 2006 | 02:01 PM
SSKILLA's Avatar
ITS A CONSPIRACY I TELL YOU!!!!!!!!!!!!!!!.................damn gremlins
Old Apr 12, 2006 | 02:03 PM
SuperHatch's Avatar
It also has to do with Turbo placement, the twin scroll turbo on the Evo is reverse rotation. You'd have to reroute the gasses in the turbine housing to get the wheel to spin the right way....
Old Apr 12, 2006 | 02:10 PM
joeymia's Avatar
quick tinfoil hats!!!
Old Apr 12, 2006 | 02:11 PM
SSKILLA's Avatar
Hahahaha Rofl
Old Apr 12, 2006 | 02:17 PM
travman's Avatar
Old Apr 12, 2006 | 03:26 PM
occultworks's Avatar
Hey, I want a tinfoil hat- I mean, direct replacement turbo... Haha! Super.
