Why did my CV joint brake?
Old Apr 13, 2006 | 11:48 AM
adamhw's Avatar
I had some work done on my car a few weeks ago, power adders 20g-9, meth, etc. Also had exedy twin hd installed. About 500 miles later I engage in some spirited driving, everything seemed smooth, I didn't feel like I was over stressing the car, or that I was having trouble with the clutch.
After a bit of driving I noticed some clunking and whining. I immediately stoped driving and called it a day. I took the car to the dealer and they said the cv joint is broken, and the cv boot is missing, so they wouldn't warranty because the boot was obviously removed. They told me $500 for part and labor. A few days later they told me the transfer case is also bad, of course not covered.
I'm dealing with fixing that, but my question is why did this happen. Did the joint brake because the CV boot was missing, Is it something that I did, or bad roads, power and weak driveline. I don't want to brake another joint what should I do to prevent from happening again, not drive hard?
Thanks in advance.
Old Apr 13, 2006 | 11:53 AM
Greg K's Avatar
yes. the cv broke because the boot was gone, and the boot holds the grease in place. The grease keeps the cv from "digesting" itself. Also any grease that is remaining in the joint will be contaminated with grit and dirt and basically become and abbrasive that destroys the joint.
Old Apr 13, 2006 | 12:09 PM
Schuyler's Avatar
Did you have the work done by a shop? If so, they should be fixing it.
The tcase makes some sense to me because the CV for the front is connected to it.
Old Apr 13, 2006 | 01:32 PM
adamhw's Avatar
Yes. It was done by a shop that specializes in evos. They denied it had anything to do with them. They installed the clutch and did other extensive labor. They said that when the clutch is installed the axle comes out in one piece, and the never did or need to touch the boot, but within 2 weeks it wasn't on my car. The dealer said the boot is crimped on so it can't fall off.
AlexGutEvo8
May 24, 2015 11:35 PM
bolc
Lancer Tranny/Drivetrain Tech
10
Feb 6, 2012 04:43 AM
Xearo
10
Aug 24, 2010 06:52 PM
Gazika
Mar 23, 2010 12:10 PM
travelsize420
Lancer Troubleshooting
Jul 6, 2006 10:51 AM
