Evo IX Compressor on Evo VIII Turbo???
Old Apr 16, 2006 | 07:14 AM
Creamo3's Avatar
Does anyone know if I can do a straight swap of the EVO IX compressor housing onto my EVO VIII 20G?? I understand that I would need the EVO IX discharge pipes and various return lines, but has this been done and if it is possible where can I get a EVO IX housing from??
Old Apr 16, 2006 | 07:23 AM
WrX Kila's Avatar
why you have one?
Old Apr 16, 2006 | 07:30 AM
Creamo3's Avatar
Are you asking if I have one, if so no I don't. If the swap is doable that is my next step in finding one.
Old Apr 16, 2006 | 08:06 AM
MalibuJack's Avatar
the majority of the components on the CHRA and the Hot side are shared between the two turbos, HOWEVER there are differences that prevent you from doing it easily. The backplate (diffuser) and bearing is different on the CHRA and it would have to be swapped which requires removal of the compressor, among a few other differences that would prevent this from being done in someones own garage. You will also need the "Install kit" which is what you already said, the bolts, coolant and oil lines, and a new discharge pipe (which will likely need to be modified to mate up with most earlier LICP's.
Old Apr 16, 2006 | 08:19 AM
kimletrim's Avatar
Registered User
You can do it, but the compressor housinge would have to be bored out to accomodate the larger compressor wheel of the 20G.
Old Apr 16, 2006 | 09:54 AM
Creamo3's Avatar
Doh!! I was hoping this was an easy swap-a-roo. Ah well, I can live w/ it until I decide to upgrade to a larger snail.
MisUnderStood
10
Jun 13, 2015 01:00 PM
7thGearRacing
Mar 12, 2015 11:47 AM
screwnutbolt
24
Nov 9, 2014 08:55 AM
M1 Autosport
Mar 22, 2010 03:26 PM
S-1
Mid-Atlantic Region
Jul 13, 2006 01:23 PM
