What does it take to rev the evo over 8500 rpm?
Old Apr 21, 2006 | 04:38 PM
jmartinez1170's Avatar
Originally Posted by Ted B
All day, until the rings collapse, until the oil pump is thrashed, or until the pistons seize - whichever comes first.
I know of 7 evo's that got a build 2.0L the best of the best in parts and there redline is 9600K. Most of them drag , One guy has a 40R brings his motor up to 9400k and shifts to the next gear well 35000k miles later and being a daily driver the car has not had one motor problem. A motor well done and well taken care of will last you a long time.
Old Apr 21, 2006 | 07:10 PM
anjapower's Avatar
Originally Posted by Ludikraut
Agreed, except for the headgasket. You may also want to think about removing your balance shafts.
l8r)
you wouldn't need arp headstuds, a good tune or a balanced crank either.
8500 RPM - forged rods, arp rod bolts, stiffer valvesprings, stronger retainers. that's all you NEED.
Old Apr 21, 2006 | 07:20 PM
timzcat's Avatar
Wow! 9,400,000 redline! And it has 35,000,000 miles on it!
Old Apr 21, 2006 | 07:31 PM
ThunderOZ's Avatar
yea...I wonder how long it take the motor to reach that rpm?
Old Apr 21, 2006 | 08:06 PM
NEW2006EVOIX's Avatar
Originally Posted by mchuang
Not really, considering the 4g63 has close to same rodstroke ratio as a b16 you can rev to 8500 with no problem. All you may need is arp rod bolts, springs, and retainers. Some people take their motor to 8000 as it is while stock so 500 extra wont require all that you just stated especially since the 2.0l motor has a great rodstroke ratio
Be careful not to end up like this guy from revving over stock's redline (7000 rpm).
https://www.evolutionm.net/forums/sh...d.php?t=189580
Old Apr 21, 2006 | 08:54 PM
Atlmethevo's Avatar
With the stock turbo I shift at 7k anything past that just loses power. Once I build it out and tune it with a 3076 I will run 8500ish or until the turbo stops making power but I am thinking it should pull to 8000ish.
Old Apr 21, 2006 | 08:56 PM
Atlmethevo's Avatar
lol, TedB knows all even though he has never been in a evo with a build motor that runs 9000+ rpm. Got to love the internet
Old Apr 21, 2006 | 08:57 PM
scorke's Avatar
Martinez gives out so much whack information, the 94 million rev thing doesnt shock me.
Scorke
Old Apr 22, 2006 | 12:03 PM
Ted B's Avatar
Ted B does not and never claimed to 'know all', but consider the fact that Ted B, offers modern standards derived from the experience of the most reputable engineering and design houses, knows how to use a calculator, and knows how to spell correctly - all of which are far more than anything you've offered here to date. But of course, this should all be sharply questioned because you've claimed to have ridden in an EVO whereby the driver shifted it at 9000+ rpm, and therefore everyone should do it.
The information I provided is intended to serve as guidance for those who are intelligent enough to consider it, research and verify it on their own, and ultimately use it to their benefit. How you use or abuse your car makes no difference to anyone else, but neither does it warrant that your habits should be applied to anyone else.
Old Apr 22, 2006 | 12:18 PM
nrcooled's Avatar
Can you rev the 4G to 8k+ with the proper parts...yes
Should you do it on a roadcourse...NO!
Repeated shifting at that RPM for 30-40 mins WILL DESTROY YOUR MOTOR...PERIOD!
I would be willing to guess that you may last about 3-4 track events then it will die a horrible death. High revs for 11-12 seconds is completely different then 30-40 mins on long, hot track sessions.
If you plan to rebuild/check the engine after every track day then I say go for it.
Old Apr 22, 2006 | 01:24 PM
ShaunSG's Avatar
The ultimate determining factor isn't so much the rod/stroke ratio, but the piston speed. A piston speed of 25 m/s is recognized as being about the limit for a properly prepared street driven engine that is expected to deliver reasonable longevity.
Mean piston speed only gives rough indication of component loads. Rough because engine speed, component masses, geometry, are not known. What helps is that some factors offset each other.
Load is the first and real limit for most anyone.
Old Apr 22, 2006 | 04:14 PM
Ludikraut's Avatar
This whole thread is getting silly. Clearly we've got a bunch of people that think they can rev their stock internals well beyond factory imposed limits. I'm just gonna grab the popcorn and will sit back to wait for the inevitable "Look what happened to my engine" thread(s) from said people (for some of whom it will be the second time around).
Come to think of it, it really doesn't matter all that much how you want to do it. Either build your engine right the first time, or rev the stock internals as high as you want ... and then rebuild after the big kaboom. Either way, you're going to "build up" your block.
l8r)
leo_99
Apr 26, 2016 08:49 AM
STIbyebye
Mar 29, 2016 08:42 AM
Migsubishi
32
Aug 25, 2013 07:20 PM
dxbevo9
14
Sep 27, 2007 04:23 AM
AllBlak
40
Oct 7, 2006 10:04 AM
