Stock Evo Ix Mr Boost Questions!
Old Apr 21, 2006 | 05:32 PM
.MM's Avatar
.MM
hey everyone,
i already did a search and im batting zero!
my question is this:
i have a completely 100% stock EVO IX MR with 8600 miles on her
since the day i got her, the stock boost gauge has read the same, but im not sure if it's right or if the car is right for that matter.
here is what the car reads:
if im in 3rd gear at 3500 rpms and give full throttle the stock guage spikes to about 1.2 bar real fast and holds 1.0-1.1 bar until redline, with very minor taper
if im in 4th gear at 3500 rpms and give full throttle the stock gauge spikes to about 1.3 bar real fast and holds 1.1 bar until redline and tapers to 1.0 bar
but...if im in 5th or 6th gear at 3500 rpms and give full throttle the stock gauge spikes to 1.4 bar and holds about 1.3 bar all the way to just before redline, where is tapers down to about 1.1
my real question is, WHY does my car make different amounts of boost in different gears
why does my car only hold 1.0-1.1 bar (according to the ghetto stock guage) in 3rd and 4th, but hold more in 5th or 6th
1st and 2nd gear are kind of the same as 3rd and 4th, harder to watch it, since the rpms rise fast
ONLY COMMENT ON THIS THREAD IF YOU HAVE AN EVO IX and KNOW WHAT YOUR TALKING ABOUT!
thanks
matt
is my car normal? should i not worry? or what?
car hasnt been dynoed or tracked to test and i havent used a better boost gauge to test either.
Old Apr 21, 2006 | 05:34 PM
emagdnim8's Avatar
its normal don't worry
Old Apr 21, 2006 | 06:19 PM
Warrtalon's Avatar
I don't see how you could search and find nothing when what you are describing is normal for every stock Evo in existence. There is more load in higher gears, so you see a little bit higher boost. Your boost tapers, because the ECU has been programmed to make the boost taper. This is why we get MBCs and flashes...
Old Apr 27, 2006 | 12:33 AM
lilnaz's Avatar
I actually was searching for this and couldnt find as good info mm just posted. Thanks, I had an idea from the other posts but you just laid it out. My car only does 1.2 in fourth, and 1.3 in fifth. So im lower then you, youre at a higher altitude too. Or is that how it works Im gonna put a mbc on soon, this should help that problem right? Sorry to hijack your thread but I think you may be interested too.
Old Apr 27, 2006 | 02:25 AM
ejcabrera's Avatar
haha i started this thread like a week before you did but here it is
https://www.evolutionm.net/forums/sh...d.php?t=195964
Old Apr 27, 2006 | 03:29 AM
RobDogg's Avatar
My first thread in Nov. I think
https://www.evolutionm.net/forums/sh...d.php?t=173775
TOAjosh
May 22, 2012 04:55 PM
Hiboost
14
Oct 12, 2008 12:51 PM
EvoBroMA
Apr 5, 2007 09:15 AM
nigletsyz
24
Dec 29, 2005 08:14 AM
anjapower
May 9, 2005 01:07 PM
