Cleaned maf (now runs like crap)
Old Apr 26, 2006 | 10:53 AM
ZK's Avatar
ZK
Originally Posted by nightwalker
The ONLY proven way to properly clean a maf without jacking it up is with a q-tip and rubbing alcohol. I have seen mafs get messed up by spraying it with brake cleaner, carb cleaner, and that electric cleaner.
+1 I've killed a few hot wire MAF sensors using cleaners on it. Those things are delicate.
Old Apr 26, 2006 | 11:06 AM
mdsevo06's Avatar
CRC is the best product for MAF's. I've used it on many other cars and trucks, it works and it's safe. You don't want to spray anything too close to the sensor, there fragile, about 10" to 12" away. Five min. is all you need to wait at the most.
Old Apr 26, 2006 | 12:00 PM
Event-Horizon's Avatar
Originally Posted by DynoFlash
As the 03 evos get older we will be seeing this condition more and more - the solution is to use a oil catch can and using a good air filter
Al, A catch-can would not help as it works only AFTER the MAF sensor. Usually a catch can is connected to the PCV valve on the backside of the rocker cover then back to the intake right before the turbo. The MAF sensors are getting dirty due to shoddy foam filters being used and not being replaced, and also from over oiling fabric-based filters. If you're going to use foam filters, make sure to replace them when the manufacture recommends them to be replaced. Foam has a tendency to break down and allow allot of dirt to pass through. For those that run K&N type filters, make sure not to over oil them. Leave them out over night to soak, and dab off any excess oil.
It's not about how old the car is, but how good your filter is
Old Apr 26, 2006 | 09:27 PM
Nad1370's Avatar
Actually a catch can does help out.
If your boosting and suddenly let off the throttle, only place for air to escape is through the blow off valve.
But not all of the air gets out. some will backpressure itself all the way to the intake pipe.
Old Apr 26, 2006 | 10:12 PM
Andrew LB's Avatar
This is the only product I have ever used on a MAF without issue. Using brake cleaner or contact cleaner isn't worth the risk.
http://www.crcindustries.com/auto/co...x?S=Y&PN=05110
Old Apr 26, 2006 | 10:48 PM
FastEvoFL's Avatar
here can you buy that stuff?
Old Apr 26, 2006 | 11:02 PM
Andrew LB's Avatar
SEARCH!!! /warr
http://froogle.google.com/froogle_cl...le&scoring=mrd
Old Apr 27, 2006 | 04:06 AM
Oh, I was unaware that air flowed backwards through the MAF and air filter...
Toekneee!
May 11, 2014 08:38 PM
eddy5201314
Aug 12, 2013 07:59 PM
mxracer916
15
Dec 6, 2011 07:16 AM
Ralliart403
49
Jul 24, 2006 11:52 PM
brandy kaiser20
24
Jun 4, 2006 03:37 PM
