Mitsubishi OEM turbo specifications (including flow rates)
Subscribe
May 23, 2009 | 01:42 PM
  #46
awesome info.
Reply 0
Feb 8, 2010 | 05:04 PM
  #47
Still no update on the evo x turbo?
Reply 0
Mar 11, 2010 | 05:36 AM
  #48
If i want to doing a re-map to the ECU with the TD05-16G(small),i didn't take 380-390 hp?
Reply 0
Aug 16, 2010 | 12:53 AM
  #49
Quote: If i want to doing a re-map to the ECU with the TD05-16G(small),i didn't take 380-390 hp?
TD05HR or HRA ?
Reply 0
Aug 25, 2010 | 09:59 AM
  #50
Hi guys,
will there be different in terms of response and power output from Evo 5 turbo vs Evo 8 turbo?
Reply 0
Nov 3, 2010 | 05:26 AM
  #51
I have a 2006 usdm rs ix. Is it confrmed which outside I have ?, I see there is uncertainty about the ix rs 5mt
Reply 0
Nov 3, 2010 | 09:18 AM
  #52
Wow! I went and looked for myself.10.5 hotside on the 2006 ix rs 5 mt
Reply 0
Dec 15, 2010 | 04:57 PM
  #53
Great info!!!!! Makes me a little worried now though, if I recall right I believe the e9 turbo I purchased may be a a RS one... :-( I'm planning on running around 30psi on e85 on it over the summer
Reply 0
Sep 12, 2011 | 01:11 AM
  #54
from what ive been told the tme turbos only the rs came with the ti-al turbine and for some gsrs it was optional. HOw does one find out whether their tme gsr turbo has the ti-al tubine or not?
Reply 0
Sep 12, 2011 | 10:01 AM
  #55
Just check the model # stamped on your turbo... Page 1 has the E6 TME info...
This is from my original document...
And these are the Part #s for each turbo...
BOTH model turbos had the SAME SIZE (10.5) titanium alloy turbine wheel. The marketing hype about "250 rpm quicker spool" only refers to the smaller TD05RA-15GK2-10.5T "standard" GSR turbo with the smaller compressor wheel... Less weight = Faster spool.
The bigger TD05HRA-16G6-10.5T which was "optional" for GSRs... and "standard" for RS/RS2s did NOT spool 250 rpm lower, since they had the bigger compressor wheel... More weight = Slower spool.
My Evo6 RS2 has the TD05HRA-16G6-10.5T. Guestimates of 150-to-250 rpm "lower spool" have been thrown around but so far, I have never seen TESTED "spool rpm" data for the bigger turbo anywhere.
My $0.02¢
Reply 0
Sep 25, 2011 | 05:55 PM
  #56
bump i didn't catch the flow rate of the TD05HRA-16G6C-10.5T (stock 9) - is it 600cfm/roughly 41-42 lb/min?
Reply 0
Sep 26, 2011 | 12:18 AM
  #57
Quote: bump i didn't catch the flow rate of the TD05HRA-16G6C-10.5T (stock 9) - is it 600cfm/roughly 41-42 lb/min?
I've read conflicting info stating 44 lb./min also... hence the "?" on my original table... (nix = Sanctifier on Zorce.com)
Quote: E9 TD05HRA-16G6C..41 (44?) lb./min.
Link--> The "Best" Turbo Upgrade for Evo 4G63 daily driver.
IMHO the more conservative reading of 41 lb./min. seems more realistic.
My $0.02¢
Reply 0
Sep 26, 2011 | 12:25 AM
  #58
yeah i would definitely say its more like 41 or so, in the other thread i was looking at it said just a hair over the evo 8 which is right around 39
Reply 0
Aug 9, 2012 | 08:13 AM
  #59
On my 9 turbo. There only five blades I throughly check the pic on 9 turbo here there six blades is it my eyes or is there something different can some explain please.
Reply 0
Oct 1, 2012 | 11:36 PM
  #60
what max boost can i get out of my stock evo 9 ?
Reply 0
