4G6-MIVEC Valve Clearance Adjustment
Old Apr 27, 2006 | 09:09 AM
zmeli's Avatar
I was looking thru the Maintenance Schedule and shocked that the MIVEC needs valve clearance checks/ adjustments every 30k. Are they shim under bucket or screw type adjusters?
Does the IX have solid lifters? I have been searching and can not verify if the MIVEC Head has solid lifters on both camshafts.
Old Apr 27, 2006 | 03:07 PM
zmeli's Avatar
Bump (or lift up to top)
Old Apr 27, 2006 | 03:56 PM
JeffR116's Avatar
Solid lifters? no way. It would be significantly louder if they were solid lifters.
Old Apr 27, 2006 | 05:58 PM
zmeli's Avatar
oops! my mistake the Manual I was looking at was on Mitsubishi's website. When I got home I checked in my manual and it does not say anything about Valve adjustments.
http://www.mitsubishicars.com/pdf/ow..._statement.pdf
Go to page 42
Old Apr 27, 2006 | 11:33 PM
wishing4EVO's Avatar
Go to page 42
It says "4G6-MIVEC engine only"
NOT "4g63-MIVEC" (EVO 9)
4G6-MIVEC is found in the Galants and probably base, non V6 Eclipses (2.4L MIVEC).
Someone can double check...I'm going to bed
Old Apr 28, 2006 | 06:48 AM
zmeli's Avatar
Thanks for clearing that up.
Old May 20, 2006 | 12:31 AM
spiderm's Avatar
Does this mean no valve adjustment is needed? My engine ticks quite loudly, but I have not had a chace to compare with another IX to see if the ticking was normal.
Thanks.
Old May 20, 2006 | 01:53 AM
MGAUTOS's Avatar
I put forged internals in my IX and my ticks quite bad when warm, i changed the lash adjusters to the 3mm items, still no difference? Im suspecting something needs to be done to the mivec when you reinstall it? Ive just stripped the motor again to check everything is ok and everything is in spec
Demon_ni2
May 19, 2012 05:43 PM
motoxxx55
11
Jun 11, 2009 12:44 AM
Noogles
Feb 15, 2008 11:17 PM
arptunner
Lancer-Mirage Compatibility Forum
26
Jan 17, 2008 04:10 AM
TTOPPOUZI
Feb 6, 2007 06:25 AM
