Garret GT2871R
Old Apr 28, 2006 | 12:46 PM
EvoPanda7's Avatar
Garret GT2871R
i wana run a Garret GT2871R turbo kit on my car. wondering if its too small of a turbo to make any real power. i would go with a gt30 but i dont think i can live with that spool up time, what type of hardware and upgrades would i need to go threw? thanks
Old Apr 28, 2006 | 12:59 PM
jmartinez1170's Avatar
I would say go with a 50Trim from ams i think they would hit full boost around the same time and you cant get a lil more power out of the 50trim then you would with the gt28.
Old Apr 28, 2006 | 01:33 PM
nigletsyz's Avatar
what do you mean by "real" power? what kind of goals are you trying to acheive with this turbo, or more importantly, your car?
Old Apr 28, 2006 | 01:40 PM
EvoPanda7's Avatar
i want something that spools around 3200 -3500 , around 350-380whp
Old Apr 28, 2006 | 01:44 PM
Drifto's Avatar
Stock turbo will do that on pump gas easily. Why waste your money?
Old Apr 28, 2006 | 02:08 PM
Tpayne84's Avatar
^^^^ +1
seriously man you just described the average stock turbo.. IMO just stick with that.
Old Apr 28, 2006 | 06:57 PM
EvoPanda7's Avatar
yea, but thats with a alky kit and really high psi levels. unless theres a way to build my motor w/o doing that =) ne sugestions thanks guys =)
Old Apr 28, 2006 | 07:49 PM
Tpayne84's Avatar
You wont need to run alky or really high boost levels to get 350-380WHP. All you would need is all supporting mods inc. cams.
Im not sure what your talking about with building your motor
Old Apr 29, 2006 | 11:51 AM
gsujeff55's Avatar
come on guys, its def not avg for someone to have all supporting mods(no ported head, no sheetmetal intake, etc) to hit 380whp on PUMP gas without meth. It has happened a very few times.
It is easy to do on race gas, and is about avg, but on pump gas....NOPE
If you wanna make 380 or so on pump gas with minimal lag get the 50 trim. its gonna spool later than 3200, but not as late as the 30r.
Old Apr 29, 2006 | 12:06 PM
yellowEVO21's Avatar
350-370 is attainable on stock turbo on 93....if those extra 10 ponies really mean alot if u want 380, run alky which will easily around there....unless you have a freakish car like Soon2bevo who hit 378 on pump w the stocker.
Old Apr 29, 2006 | 09:38 PM
gunzo's Avatar
forget it.. this turbo is not a match for 4g63..
I had the same thinking as you before.. this was wat happened
1. it is sooo much slower spooling than stock.. try starts waking up at around 3000rpms full boost at 4500rpms
2. it makes the same power as stock at the same boost level.. you need mega boost to make it perform ie 26-27psi..
3. it tapers off at higher rpms and you get the same boost drop..
conclusion?
the 2871 is a mismatch on the evo..
slow spool, narrow powerband, same or only slightly better than stock.. I'd stick with stock or go gt30 don't waste your time
get the gt3071wg .. its like 100 times better
2-300rpm slower boost
you get your whp at around 20-21psi..
drown it with high octane or alcohol crank up the boost and its 400 easy..
Old Apr 30, 2006 | 12:56 AM
Tpayne84's Avatar
He never said he ONLY wants 380... he said 350-380, and i said thats way possable to do with the stock turbo without alky and it is. Why waist all that money on something you dont need?
mikenacarato
Mar 22, 2019 10:54 PM
SKY888
May 8, 2018 01:44 PM
riceball777
21
Dec 12, 2015 07:18 AM
drivethrufinch3
For Sale - Part Outs
24
Sep 12, 2006 10:34 AM
Rcebowl
May 20, 2006 05:05 PM
