black inside the plenum
Old May 1, 2006 | 02:05 AM
ItalianEvo's Avatar
Hi all,
a week ago I removed the throttle, and I found the plenum to be ok to my eyes.
But when I cleaned it with some white paper, the paper became black !
Engine is 1000 miles old.
Do you think it could be due to reversion ?
Have to try to retard intake cam of a pair of degrees ?
TIA !
Bye...
Old May 1, 2006 | 12:56 PM
RaNGVR-4's Avatar
Your post makes little sense, but i would say its exhaust gas recirculation doing its thing and to not mess with timing at all.
Old May 1, 2006 | 03:42 PM
ItalianEvo's Avatar
Sorry, i forgot to tell you that i have no more the egr...
Old May 1, 2006 | 04:03 PM
C6C6CH3vo's Avatar
If you got no more EGR then it must be the remaining molybdenum grease on the TB plate that the mitsu assembler overserviced from the factory.
Also, if you still have the rubber ducting it's netorious of yeilding black crud. For example, take a wet cloth and wipe the inside of the hose - black, do it again - same, the rubber will just give off the crap as long as it's in there.
Old May 2, 2006 | 12:21 AM
ItalianEvo's Avatar
No, I don't think it comes from before the throttle... I changed every rubber ducting to silicone ones !
Old May 2, 2006 | 06:01 AM
EVO8emUp's Avatar
It probably developed between the time the car was first started and the removal of the EGR.
Old May 2, 2006 | 11:19 AM
ItalianEvo's Avatar
Nope... as I told the engine was rebuilt 1000 miles ago...
Old May 2, 2006 | 01:38 PM
RaNGVR-4's Avatar
probably didnt clean out the intake manifold. dude its not a big deal, insides of engines get dirty.
Old May 2, 2006 | 01:43 PM
broddey's Avatar
crank case oil gets aerated and sent back into the intake system. It is a normal occurrence, but many people install oil catch cans to remove this, because it robs power from the engine, forcing it to burn that recirculated oil.
Old May 3, 2006 | 01:19 AM
ItalianEvo's Avatar
Exactly,
in fact I routed to atmo the oil vapours many years ago...
Old May 3, 2006 | 09:29 AM
EVO8emUp's Avatar
Broddy... good call. I forgot all about that!
Erik@MIL.SPEC
365
Aug 29, 2017 12:59 PM
El Boricua
Feb 8, 2016 12:53 PM
Evo5madness
Nov 1, 2013 02:05 PM
evotris
Jan 2, 2013 10:01 PM
omniprobe
Mar 29, 2011 09:24 AM
