Installed deck but now some of the lights in my car dont work?Hellp plz
Old May 2, 2006 | 08:54 AM
Evolution8Blue's Avatar
OK i installed a deck a week ago it went smoothly the deck works fine....but now my lights for the ac and heating dont work......my boost gauge doesnt (tapps the dimmer switch, the cighterlighter rings light doesnt and the ashtray light are all out.....ive checked fuses all that i know of are fine (ones behind dimmer switch and ones under the hood)......i check with the multimeter if any powers coming to the dimmer switch and there is none so somethings burnt out or messed i just cant find it and its now getting to me when i drive at night it seems so friggin dark in the car..........
so can someone point me in the right directions or help me out cause this sucks.....thanks alot i appreciate it..
Old May 2, 2006 | 08:59 AM
stevEVO8's Avatar
Did you use a harness for the install or did you cut and splice the factory harness?
App420's Avatar
same thing happened 2 weeks ago to me. right tail light probably doesnt work as well. Its a fuse under the hood. read the manual i remember it was 15 amp.. check manual and you will see that it burnt out...
Old May 2, 2006 | 09:01 AM
ya your right the tail light doesnt work....thanks alot
Old May 2, 2006 | 09:02 AM
App420's Avatar
np
Old May 2, 2006 | 09:03 AM
NoTec's Avatar
Probably a fuse under the hood. Also if the harness has an orange wire and your deck has an orange wire, make sure they are both either solid orange or both orange with a white stripe. Because mixing both wires will blow the dimmer/park light/dome light fuse every time. Ensure that the wires are hooked up correctly and match each other. Then check the fuses in the car and under the hood. If you have difficulty finding the blown fuse, check all of them one by one.
rosuegk7
Apr 19, 2017 08:28 PM
oUBDo
14
Aug 22, 2015 08:01 PM
machron1
Northwest Region
25
Jun 24, 2007 11:00 AM
zze86
Nov 1, 2005 01:01 PM
wd_cross
10
Sep 12, 2005 07:43 AM
