650CC injector out of a DSM into an EVO?
Old May 3, 2006 | 05:01 AM
blackbichGSX's Avatar
I have a 97 GSX that has 650cc FIC injectors. I am going to return the car close to stock and sell it. I want to put the 650cc injectors into the EVO since they are rather new. So my question is are these injectors compatable? I realize I will have to retune and all that good stuff, I just don't know if they are swapable. FIC has different part numbers for the EVO and that threw me off.
Old May 3, 2006 | 06:30 AM
Soon2BEVO's Avatar
Id like to know this as well. I heard from somewhere the only difference is a clip or something? Of course, that might be compeltely false so I look forward to seeing a concrete answer.
Old May 3, 2006 | 06:44 AM
GHEvo8's Avatar
i dont no if this helps but i swaped my stock injectors into my buddys 97 gsx so i figure it should be but dont quote me on that
Old May 3, 2006 | 06:49 AM
MitsuEvoIIX's Avatar
im pretty sure that they are exactly the same. I had injectors i sold off of my eclipse and i was an idiot b/c i didnt even try them in the evo and i ended up buying the same ones back for like 50$ more
Old May 3, 2006 | 06:54 AM
Eclipsed Evo's Avatar
No they wont fit. How do I know? I bought some FIC 750cc injectors for my evo but grabed the wrong box. The injectors I bought were 750cc for an eclipse. The end of the injector on the eclipse version is flared out and will not fit into the evo. So what I did was take a dremel tool and ground down the flare til it fit. So with a little work they will fit.
Old Jun 16, 2006 | 05:55 AM
That was not the answer I was looking for. I have read some articals of people trying to put 750cc injectors from a DSM into an EVO with no success. I was not sure if this fitment issue was due to the size of the injector or if it was due to somthing else. I guess I will just sell the injectors and get EVO style injectors. Thanks
Old Jun 16, 2006 | 02:40 PM
evolved4g63's Avatar
Thats the same thing FIC does if you order the evo injectors. Just grind down the flare/ bowl/ bell and your good to go.
Old Jun 16, 2006 | 03:33 PM
Gruppe-S's Avatar
I believe the on (dead) times are different also! We have some Helix 720cc's in stock if you're interested. They're Denso cores and direct drop in. The FICs sometimes seem to have a varying flow rates which sometimes makes for strange tunes...
Cheers,
Gary
Gruppe-S
Old Jun 22, 2006 | 09:28 AM
kjewer1's Avatar
In my experience the FICs flow ***** on to what they are rated at. Deadtimes seem to be fairly well matched, but I don't spend a lot of time tuning closed loop anyway. Based on the results I've had I only run FICs now. But I've only run 6 sets or so, your mileage may vary.
To add to what was posted above, it is correct to say that EVO injectors will fit in a DSM, but DSM injectors will not fit an EVO, for the reasons given above.
Evo VIII 4o1
17
Nov 16, 2015 10:32 AM
aquaMan219
Jun 17, 2015 06:06 PM
4g64t_dohc
Dec 13, 2011 02:37 AM
extremepsi
49
Nov 12, 2008 09:11 PM
ak1
Feb 23, 2005 04:40 PM
