evo 9 turbo on evo 8 question
Old May 13, 2006 | 08:29 PM
hondafan's Avatar
Question evo 9 turbo on evo 8 question
i was just wondering if anyone out there knows for sure whether or not a 9 turbo will bolt directly up on an 8 without modification. are the oil/coolant lines the same? if not, which should be used? i assume it bolts to the manifold fine, but what about the elbow that leads to the IC piping? is it the same? if not, which one do you use? please only give answers to these questions if you know for sure. thanks.
Old May 13, 2006 | 08:34 PM
Stinkapuss's Avatar
Some of the oil and coolant lines will have to be bent. You will need an Evo 9 turbo outlet pipe to clear the starter.
Old May 13, 2006 | 08:39 PM
hondafan's Avatar
thanks for the info. was it a nice difference swapping to the 9 turbo? i see you're running one in your sig. also, which lines did you use 8 or 9? are they a PITA to bend or is this something a mechanically inclined person can accomplish easily? thanks again.
Old May 13, 2006 | 08:40 PM
Nad1370's Avatar
Outlet pipe on the 8 will fit the 9.
But you will have to re-position the starter cable because it comes to close to the pipe.
Mine did not hit but it was close so I just re-positioned mine just in case.
Your choice though.
Old May 13, 2006 | 08:42 PM
hondafan's Avatar
well since the lines need replaced when i swap turbos, which should i buy?
Old May 13, 2006 | 08:45 PM
Stinkapuss's Avatar
It was a pretty noticable difference. I used the stock 8 lines. They have to be bent to clear the bigger housing and it's pretty easy.
Old May 13, 2006 | 08:52 PM
hondafan's Avatar
so the 9 lines wouldn't be a direct bolt on? i figured they'd connect to the engine in the same locations, am i wrong?
Old May 13, 2006 | 08:54 PM
Stinkapuss's Avatar
They 9 lines will bolt right on.
Old May 13, 2006 | 09:00 PM
hondafan's Avatar
alright, thanks man. sounds like a pretty straightforward swap. one more question, the 9 elbow connects to the 8 IC pipes without modifying, right? also, do you hyave any before/after dyno #'s?
Old May 13, 2006 | 09:18 PM
hondafan's Avatar
oh, and the 02 housings are the same, right? if not, which is the preferred housing?
Old May 14, 2006 | 06:03 AM
Stinkapuss's Avatar
Yes.
also, do you have any before/after dyno #'s?
Just after, 375/386 on race gas.
