Just finished the gsc 272 camshaft install...
I just put in my gsc 272 camshafts follow the evomoto.com guide
I also put a fuel pump in the cams only took about 4 hours to do.....the install was actually very easy and straight forward you just need to make sure its all times right and everything.....
Now my question is i had a tune before but now i added this and fuel pump can i push the car yet? or am i going to screw something up, im waiting till the alky kit arrives so i can get the tune for all of them, instead of wasting the money to get it tuned twice.....
https://www.evolutionm.net/forums/sh...d.php?t=200544
yeah the evomoto.com guides are top notch... clutch and flywheel install took 2 days with it... and i've never dropped a trans in my life... someday, the timing belt and hopefully cams will be on the list of things to do
I also used the evomoto guide for my cam install last week for my comp cams 272's. Made it very easy. I was debating whether to bleed the lifters or leave it as is. I'm glad I bled them after I found out how easy and fast it was. No ticking sound here.
fareastkorean
45
Sep 10, 2005 04:01 PM
RalliArtEvoVIII
21
Sep 10, 2005 11:22 AM
