ARPs or with cams or not?
Old May 20, 2006 | 02:01 PM
Jeff_Jeske's Avatar
The only reason you would need studs is if you have a bad tune.
The stock bolts and head gasket are very strong as long as they aren't abused.
350WHP road race tune stock junk.
Old May 20, 2006 | 02:13 PM
Cirrusly Evolvd's Avatar
It's all about piece of mind...if you're getting cams installed you might as well add the ARP studs at the same time. I trust what I was told by AMS before I trust a bunch of keyboard knuckle busters.
Old May 20, 2006 | 05:49 PM
kjewer1's Avatar
Originally Posted by kjewer1
Knock is much more likely to stretch a stock bolt, and all that takes is a bad tank of gas no matter how good your "tune" is In my humble opinion the stock stretchy bolts are just too much of a liability.
There are many things that can cause knock besides the tuning. Why take the risk? The stock stretchy bolts are not strong by any means! This has been proven for years on the 2Gs, which use similar bolts (wouldn't surprise me if they are exactly the same). While avoiding knock is the best way to keep the stock bolts happy, it's not the way I like to do business on a regular basis. Some poeple get lucky. I'd rather do it right purposely than hope I stay "lucky"
Old May 21, 2006 | 12:19 AM
fst4door's Avatar
When I had my cams installed this past week I was advised by shop to add ARP studs as well.
Old May 21, 2006 | 05:32 AM
Richard Sierra's Avatar
My head lifted running 23 psi. As someone else posted, the two bolts closest to the trans were loose and had stretched. My tune is fine.
I'd put them in.
Old May 21, 2006 | 06:38 AM
Jeff_Jeske's Avatar
Okay....point taken....but if you say do head bolts then I suggest actually pulling the head instead of doing one bolt at a time. If you are going to do it right ..... do it right.
Old May 21, 2006 | 07:26 AM
kjewer1's Avatar
I agree wholeheartedly with that as well. It's so easy to pull the head on these cars, I can't see a good reason not to. It's only a couple hours work if you don't need to do a tbelt job, and it's a good chance to clean off the piston tops while you're in there (mine had heavy deposits even at less than 20k miles).
Bman513
Sep 13, 2016 01:12 PM
alexc
Jun 20, 2016 07:14 PM
malachi
Dec 21, 2006 01:38 PM
SMrider102
Apr 6, 2005 08:21 AM
evoracer32
Jan 5, 2005 11:08 PM
