cams and head gaskets
Old Oct 23, 2006 | 07:27 AM
Jeff_Jeske's Avatar
Originally Posted by Silver Knight
I have nearly 40K miles and I'm doing cams (264/272) as well. Does it make since to do the timing belt, balancer belt and water pump now? Also, are the OEM belts fine for mild modifications such as TBE and cams?
I wouldn't change any of those. 40K miles is still like new if you ask me.
Old Oct 23, 2006 | 08:35 AM
kjewer1's Avatar
Not to mention that it's so easy to do this job on the EVO going through it at 60k is hardly a setback. I think I did the last tbelt swap on my EVO in under an hour from jack up to jack down. MUCH easier than DSMs, FWIW.
Old Oct 23, 2006 | 08:58 AM
Kee1pride's Avatar
Originally Posted by fq340
i did search but didnt really find the exact information i'm looking for....
i'm about to have my cams installed and according to the search i did, most people recommend replacing the head gasket also... should i get an new oem head gasket from mitsu or an aftermarket one like cometic? are new cam gears required too? forgive my newbiness..
the head doesn't need to be removed to install cams nor does it need to be removed to change out head studs.
just remove the valve cover, unbolt the cams and the sensor, stick em in , adjust, torque everything back to spec and stick the valve cover back on.
as fasr as head studs just reach down and unscrew the stock ones with an allen wrench and stick the new ones in. no need for a long drawn out head removal.
don't take the head off and leave your head gasket alone. the stock one is fine. AMS uses the stock head gasket on their 8 second evo. the rest is a waste. unless your head gasket is actually blown then just leave it alone. i repeat, leave it alone
Old Oct 23, 2006 | 09:27 AM
Silver Knight's Avatar
Thanks for the replies guys. A couple more questions, do the valve cover gasket and cam seals need to be replaced or anything you can think of that'll I'll need?
Old Oct 23, 2006 | 12:24 PM
Jeff_Jeske's Avatar
There are a few things you will have to decide for yourself.
1. When installing the cams, are you going to bleed your lifters?
2. Do you really think head studs are needed in a cammed evo?
3. If you do feel studs are needed are you going to do the job the right way or use the one by one method of swapping them.
I won't get involved in telling you what to do or not do. I will tell you that I have a cammed EVO that has been running like a top for 30k miles. I do not have studs and I didn't bleed my lifters. I go with the "if its not broke don't fix it" approach. Others tend to feel a fairly cheap safety net isn't such a bad thing to have. This will be entirely up to you.
Old Oct 24, 2006 | 06:45 AM
1. I'm paying someone to do it and with the reading I've done on evom I'm going to ask it to be done. I don't want to take the chance of the lifters ticking.
2. As far as head studs go I thought it was a question of boost pressure not if you run cams or not. I won't be exceeding 22psi so I don't see the need.
3. N/A see #2.
evoboy2006
May 1, 2013 06:53 AM
ilikeppie
10
Dec 25, 2011 09:03 AM
hytek369
17
Aug 1, 2008 09:25 AM
sonicnofadz
Apr 3, 2007 09:15 AM
FlyNavy
Jun 27, 2006 10:35 AM
