Driveline Lash...again
Old May 29, 2006 | 07:27 PM
RogueSTi's Avatar
Guys, Im sorry to re-re-visit this topic...but it's driving me NUTZ!
I have a LOT of lash in the driveline/drivetrain/whatever. I tried an Ingalls ETD, but it didn't help much. Then I dropped in the Forge front motor mount. Again, not much help. The car rocks forward and back like MAD.
I can't see if the engine is moving, causing the problem. I even drove around with the hood removed, but I can't really see.
I am at the point now where I hate driving the car.
Could this be in the transfer case?
The tranny is freshly rebuilt by Mitsubishi, and I made them double check the tolerances, so I dont think it's the tranny.
Thanks!
BTW, if it matters, I have the Exedy twin disc clutch.
Old May 29, 2006 | 07:43 PM
Noize's Avatar
EvoM Administrator
Give me a ride in the car. Call me f00.
Old May 30, 2006 | 05:24 AM
RogueSTi's Avatar
you never answer the phone.
Old May 30, 2006 | 05:42 AM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
I have noticed this kind of bucking after i got my exedy twin installed as well. Its not intolerable but its there. I'm thinkin it might have sumthin to do with the springs in the disks maybe? Do you have cams?
Old May 30, 2006 | 05:55 AM
Blue Evo 8's Avatar
I know what you guys are referring to as it has happened to me, what I did to solve the problem is install the rear motor mount upgrade, after that all my sounds and problems went away
Old May 30, 2006 | 06:04 AM
RogueSTi's Avatar
At this point Im willing to try nearly anything. Ill try the rear motor mount upgrade. Where did you get yours? Is the installation tricky?
Old May 30, 2006 | 06:05 AM
RogueSTi's Avatar
Yes, I have the HKS 280s that idle like an old Chevelle.
Old May 30, 2006 | 06:18 AM
Blue Evo 8's Avatar
Yeah I'm running the Buschur Racing front and rear motor mounts, the rear installation is tricky, and if you dont have a press or a way of melting out the old bushing then you're screwed
Old May 30, 2006 | 02:15 PM
trinydex's Avatar
what do you have done to your car?
Old Oct 15, 2006 | 08:32 AM
RogueSTi's Avatar
Update:
Recently I removed nearly all my aftermarket modifications in preparation to sell/trade the Evo. With the stock cams and stock motor mounts in the car, the "rocking sensation" that Im talking about is reduced quite a bit. I test drove a IX this weekend and it has the same rocking sensation, only not as bad. I think that the rocking is more pronounced in my car due to the Exedy twin disc clutch (you can "hear" the rocking becuase of the noisy clutch)
I had tried Urethane motor mounts (front and rear engine mounts), Ingalls stiffy ETD, and had the tranny/transfer case looked at by the dealer. All of the motor mounts and ETDs made the problem WORSE - or at least much more evident. 3 different mechanics all agreed that there is no problem, that it is normal with AWD vehicles, so I guess Ill put this topic to bed for now.
Old Oct 15, 2006 | 02:46 PM
trinydex's Avatar
this doesn't sound right... it would appear you have something installed incorrectly, possibly your clutch (maybe warped housing) or something else in teh driveline. something that is misaligned is allowing you to hear and feel this and somehow it gets worse with the motor mounts.
notice that others have only cited that their lash goes away with motor mounts. you obviously have something else as a problem.
Tw3NTy0n3
May 21, 2016 11:24 PM
d didit
Jul 11, 2008 11:00 PM
KazzEvo8
15
May 30, 2008 02:13 PM
Slava
Feb 2, 2008 07:03 AM
zwampy
Apr 13, 2007 03:19 PM
