CUSCO Pressure plate Retainer Clip????
Old May 31, 2006 | 10:13 AM
Nesiop's Avatar
I am not sure what it is called and don't have a picture of it, but I am told by Shep and Adam@Z1 it is not an OEM part...
Referring to a Cusco Twin Cerametallic clutch:
The part I am referring to belongs to the pressure plate of clutches that goes around the TOB in your clutch. As people may have known I was at the track a couple weeks ago and my clutch got stuck to the floor so I ripped it out and sent it to Shep since it was out. But I still need this little clip that is a circle with little finger tips or hooks on it with a wave ring that goes around it.
Adam contacted Cusco for me and they said they do not sell it seperately, and he is waiting for a response from Exedy (Thanks Adam, best vendor I have even known, worked with, anything). If they say no then what am I to do to pick up this tin POS of a part that will prevent my car from running.
Can the OEM one fit, does the OEM one use one etc etc.....
Old May 31, 2006 | 10:33 AM
Nesiop's Avatar
MalibuJack called them Snap rings/Thrust Washers, so assuming thats the part name... Need to find a pic...
Old May 31, 2006 | 10:41 AM
MalibuJack's Avatar
Yeah its some sort of snap ring.. Not sure where you will find one though.
Old May 31, 2006 | 10:53 AM
MalibuJack's Avatar
nevermind, saw what he was referring to, its definitely NOT a snap ring..
Old May 31, 2006 | 11:00 AM
Nesiop's Avatar
http://evomoto.com/tech_info.php?tec...bb1863eccfa27f
Kinda looks like number 34. bottom pic...
Old May 31, 2006 | 11:03 AM
Nesiop's Avatar
http://exedyusa.com/technical/files/...ndamentals.pdf
In this PDF on page 3 it looks like it is the Friction Plate and cone spring....
Old May 31, 2006 | 12:13 PM
SuperHatch's Avatar
That is the TOB retainer clip. According to Exedy's spare parts catalog breakdown, that is not available separately. However, try calling Exedy direct to get an answer.
http://exedyusa.com/technical/files...undamentals.pdf
That is not the same part that you are referring to above. What you are looking at in this link is the clutch disk itself.
- Steve
Old May 31, 2006 | 12:32 PM
Nesiop's Avatar
Hmm... When I get out of work I am going to try and get to my buddies shop to take pictures of it to get an accurate part explanation...
Old May 31, 2006 | 03:49 PM
Nesiop's Avatar
Here are the pics... With the washer or whatever around this ring it slid over the TOB and clipped into the Pressure plate. Sorry on the size of the pics/quality, Putfile messed them all up.
The ring with claws: And a piece of metal I found inside the tranny when we seperated it from the clutch:
That little piece of metal:
The backside of the ring:
The washer I believe Shep told me to get multiple ones and put together to put around it to avoid this again:
The ring with the washer around it (Not positioned correctly):
Old May 31, 2006 | 04:48 PM
Nesiop's Avatar
Going to buy the new part with all those pennies on my desk...
Old May 31, 2006 | 04:51 PM
ACTman's Avatar
The factory uses the same parts. The stock clutch came with one wave washer but Exedy changed to two over a year ago. Exedy doesn't sell them seperately. Your best bet might to rob parts from a used clutch believe it or not. You can check with Mitsu though to see if they sell it seperately. Good luck.
Old May 31, 2006 | 05:01 PM
Nesiop's Avatar
Oh, I heard from a few people it wasn't the same part mitsu had..... And that other little metal piece... that goes to?
Old May 31, 2006 | 08:00 PM
SuperHatch's Avatar
I have a spare, but I was keeping it for myself for this very reason...
Old May 31, 2006 | 10:05 PM
Nesiop's Avatar
Where ya get it...
Old Jun 1, 2006 | 01:05 AM
trinydex's Avatar
superhatch should be clutch guru.
