Coil on plug diagram - should help some out
The settings I provided you with were the DSM Coil Settings, the reason I posted them becuase if you look the base cal for the DSM it has different settings than the wizard (MIN Tooth I believe). This could of changed depending on the install of software that you have so I just wanted to post them up to make sure you could test the same that I run. As for the 300m coils I have always been told to use the viper settings so those should of worked, I would think if you are getting low rpm misfire it does sound like a dwell problem so you might play with the lower rpm dwell to see if you can clear it up.
Good luck
Good luck
Want to build me a coil on ignition? PM me if you are interested.
I will sell my HKS DLI II ASAP! I still get hiccups while using the HKS DLI II and I don't know why. Someone told me to junk the Magnacore 8.5 wires because they cause problems?
im running the DLII W AEM in my car & have not have any negative issues W the two interacting (base cal dwell settings)
...................................""Update 10-9-06"" DLiII or harness has failed, waiting on new HKS DLi harness to confirm whether DLi unit or harness failed ....................................
now thew magnecore's are a diff story, i had the 8.5's & had nothing but problems W them, both before & after installing the DLII. problem finally went away when switched back to OEM wires...... i agree, the magnecore's fit poorly as well
Thanks
Great stuff, thanks
Originally Posted by TrinaBabe
And if you want to simply use just the DSM ignitor and coils you can skip all the wiring going to the coils, just leave the DSM wiring from the ignitor to the coils and it will work fine (You will need the 4 spark plug wires as well). That would be the cheap way to fix any ignition problems (Junkyard out the DSM stuff for $20).
Both of these ignitions are proven to hold at least 35psi w/ a 150 shot of nitrous with no other ignition amplifier. For a $20 ignition you cant complain
Still using the DSM stuff and its working great... figured I post that up as an update
My car is now tore apart but I never ran into an ignition problem since I swapped over to this method. Car would pull great at 30+ psi. Plugs also did stay cleaner for longer.
Trina - Did you ever get the car working with the COP 300M Coils?
Also could I do this on stock ECU?
How would I change the "CAL" values you keep referring to?
