Surging issue
Old Jun 17, 2006 | 04:07 PM
Girlie's Avatar
Surging issue
Well, I have been fighting a surging issue with my IX for some time now. The problem is much worse when it is colder outside, so it hasn't been as bad lately. What happens is under slight boost >10psi cruising if I let off the gas it bucks really bad. I spoke to Clay about it and he said it was surging. So I changed my driving habbits to let off fully to prevent this, although at times it is pretty hard to do in normal driving.
Anyways, I decided to try an expirement today to see if it helped any. I VTA the bov to see if it made a difference. Idle was fine, driving at first was great, no more surging at all. That lasted about 3 miles and it started the same surging again.
Any other IX owners expierencing this?
Car has an intake, MBC, TBE, and flash. Thats it.
Girlie
Old Jun 17, 2006 | 04:10 PM
evo-boy's Avatar
my 8 surges alot, i just let off slowly and usually that helps.
Old Jun 17, 2006 | 04:11 PM
Girlie's Avatar
On mine the slower I let off the worse it gets.
Old Jun 17, 2006 | 06:10 PM
boostin''s Avatar
Registered User
evo-boy find out whats causing you're 8 to surge?
Old Jun 17, 2006 | 06:24 PM
occultworks's Avatar
Girlie, is your MBC T-ed into the same line as your BOV? Others have experienced surging/fluttering when it was done that way.
If that's the case I would try a different source.
Old Jun 17, 2006 | 08:34 PM
Danny23's Avatar
are you using the stock BOV?
Old Jun 17, 2006 | 10:37 PM
Girlie's Avatar
Stock BOV
MBC is ran from the compressor cover.
Girlie
Old Jun 19, 2006 | 11:45 AM
nigletsyz's Avatar
Sounds like your BOV isn't fully opening.
PINK LANCER
Lancer Engine Tech
Nov 9, 2013 08:11 PM
l2r99gst
Sep 17, 2009 07:12 AM
JDMevoBOOST
71
Jul 25, 2008 04:54 PM
zyounker
Oct 26, 2007 12:42 PM
3volution8
May 24, 2007 04:59 AM
