Intake for an EVO IX
Old Jun 23, 2006 | 10:26 AM
  #46
Warrtalon's Avatar
Originally Posted by lowbdgtmechanic
yes if you read my previous post here. i said "HKS RS intake then get a tune"...Now about the BOV, base on someone elses expirience not mines[sorry], well he put blitz bov then hks and his car ran like sh*t. so he went with hks rs then tune right away.
We weren't talking about the Blitz or HKS BOVs, both of which vent to atmosphere. We were talking about the JDM MR DV that comes stock on Evo IXs. It recirculates and works perfectly. You just got confused.
Old Jun 23, 2006 | 10:31 AM
  #47
fsugatorbait's Avatar
Originally Posted by KOEvo
Al is the one who made that thread dude, did you even click the link? wtf. I was agreeing with his findings.
Al does recommend intake, as well as BR, cool. But all i'm saying is why waste the money when it's been proven to provide little to no gains, and stock has no restrictions. Like i said, i'm not going to dig up the studies done, but i have seen plenty, search for yourself. Warr went 12.0 on stock intake, you think he would have ran 11's w/ a cone? DOUBTFUL. Looks like he saved himself $200, i would rather buy race gas.
Yeah, I read the thread and it backed what I was saying. If you would have done some more reading in Al's forum a gentleman lost 11whp and 4ftlbs by going back to the stock intake w/K&N filter from the HKS piece with moderate at best power levels...
https://www.evolutionm.net/forums/sh...ghlight=intake
Ill take 10whp any day of the week for $150. This argument is a mute point from here on out given this information. Next...
  #48
lil'evil_evo's Avatar
Originally Posted by EVOtagger
of course Al and other VENDORS are going to recommend it...THEY SELL IT AND MAKE MONEY OFF IT!!!!
why would they recommend keeping the stock intake when they can make money off all the newbs
Last time I checked Al does not sell intakes.
Old Jun 23, 2006 | 10:32 AM
  #49
Warrtalon's Avatar
Yeah, Al doesn't sell these intakes - he just provides the info to us that he learns from tuning/dyno'ing so many Evos.
However, regardless of the gains you see on an intake ON A DYNO, that does not translate to road power with the hood down.
Old Jun 23, 2006 | 10:36 AM
  #50
War, you should know that given the aerodynamics of the evo the hot air is relieved through the hood vent. The air under the hood is not stale like it would be sitting in a room on a dyno. If you leave the stock snorkel in place, cooler air is being directed towards where the cone filter sits.
Old Jun 23, 2006 | 10:37 AM
  #51
lowbdgtmechanic's Avatar
WHOOPS...sorry...
Old Jun 23, 2006 | 10:45 AM
  #52
Warrtalon's Avatar
To some degree yes, but the air is still not sealed off from the engine heat like it is when using the stock airbox.
On a dyno, the stock airbox gets nothing more than the fan in front of it, which the open element intake benefits from just the same, if not more. It's not like that with the hood down on the road OR on the dyno.
Old Jun 23, 2006 | 10:51 AM
  #53
KOEvo's Avatar
11 whp and 4 ft lbs isn't worth a siezed dirty azz motor to me. If it is to you, just take off your intake completely, i bet you'll gain even more power.
NEXT
  #54
EVOtagger's Avatar
no, but he walks hand in hand with vendors that do
I generally take Al's findings with a grain of salt. If you are going to mod based on one person's findings, why not take into consideration other tuners/vendors findings? Vishnu guys are running their stage 2 and 3 kits with stock boxes making over 400whp. I know a couple guys making over 400whp on a Mustang dyno running the stock airbox and a 20g-9 and race gas with a flash
The fact is, the stock airbox is perfectly fine for anyone running a stock turbo or equivalent. Most of the people in this thread are wanting an intake based solely on the sound anyways. Aftermarket intakes flow inconsistant air past the MAF...even with a tune, there is no way to regulate airflow through a cone filter. It may look pretty on the dyno with a fan blowing the same amounts of air constantly into the filter, but as soon as the hood is closed and irregular amounts of air are moved across the surface area of the round filter, you are going to see irregular MAF readings...the factory airbox regulates that airflow for the factory MAF sensor to read
Old Jun 23, 2006 | 10:57 AM
  #55
yellowbirds58's Avatar
Why did you say that lowbdgtmechanic? The JDM MR DV is an OEM BOV that works perfectly. WHy would you say it will run like sh*t? An HKS intake will make you run poorly without a tune, but not a JDM MR DV. Hell, that's your STOCK BOV - did your car run like crap from the factory? No.
Reggie, the JDM MR DV (stock IX BOV) makes almost no noise with the stock intake. It's purpose is not to make noise, but rather to release pressure when under boost and letting off the gas so that the compressor wheel is not damaged.
Aha!!
Ok, thanks for clarifying that
I didnt know That's why I'm a noooooob
Another noob question in regards to the JDM BOV, is it better then the USDM BOV?
I heard from someone that it increases the boost by a few, but I'm not sure how?
Old Jun 23, 2006 | 12:17 PM
  #56
silvery_eagle's Avatar
Originally Posted by xxx4reggie
Aha!!
assuming that you do not have an EVo yet, and are planning to buy a new one, then NO the JDM BOV is the same as USDM BOV on the evo 9
Old Jun 23, 2006 | 12:22 PM
  #57
Warrtalon's Avatar
Reggie, please change your profile to show what Evo you have. If you truly have an Accord, then you're wasting our time a bit with these questions. If you have an Evo and need this info to make decisions, then we need to know if you have an VIII or a IX. The USDM VIIIs (03-05) all came with a plastic BOV that is crappy. However, the USDM IXs all came with an aluminum BOV that is identical to the JDM MR DV. It is an awesome unit that performs flawlessly up to 24-25psi. No, it does not raise boost - not sure where that came from. I recommend not listening to "someone."
Old Jun 23, 2006 | 12:49 PM
  #58
NEXT
LMAO!!!
You're kidding, right? That has to be the best response I have ever read on here. I dont think I can ever take another thing you say seriously after reading that.
Old Jun 23, 2006 | 01:10 PM
  #59
theEVOdream's Avatar
the horror....
  #60
Ah, sorry about that guys, I was reffering to the IX's.
Just wanted to clear up that question.
Thanks
