gt35r+meth aem tuned dyno #s
Old Jun 24, 2006 | 01:24 PM
levo2nr's Avatar
Originally Posted by smokedmustang
Some people are driving with stock block and stock head with the GT35R, so yes.
Nice Job!! Come out and give me a ride!!
come on out to philly area ill give u ride
Old Jun 24, 2006 | 01:26 PM
levo2nr's Avatar
Originally Posted by SiCKlEyWiKeD
sweet! any plans for a stroker?
no stroker, im just going to build my 2.0 motor
Old Jun 24, 2006 | 01:27 PM
levo2nr's Avatar
Originally Posted by Evo VIII 4G63
ill be going to sean for my 35r tune very soon.
seans the guy to go to
dont forget to post up ur numbers
Old Jun 24, 2006 | 01:28 PM
Derek888's Avatar
do it!
Old Jun 24, 2006 | 01:29 PM
levo2nr's Avatar
Originally Posted by Rcebowl
sorry if this is a dumb question.. .that bar that goes down at the 6k line.. what is that?
i would tell u but i have no clue what that is myself
Old Jun 24, 2006 | 01:30 PM
levo2nr's Avatar
Originally Posted by Derek888
do it!
i would but im still recovering from these upgrades u know what i mean
Old Jun 24, 2006 | 01:31 PM
Derek888's Avatar
l
Old Jun 24, 2006 | 01:43 PM
Eclipsed Evo's Avatar
Was this on C16 or some other race gas? Just seems like 30psi would be a bit high on pump gas. Either way sounds like its a monster.
Old Jun 24, 2006 | 01:50 PM
levo2nr's Avatar
nope no c16 just pump and 100%meth
Old Jun 24, 2006 | 01:59 PM
jbrown's Avatar
The line at 6k is just a marker to tell you that at 5900rpm you are making 487.24 hp and 430.38 lb-ft of torque. If you use the left and right arrows (on the dynojet software) it will move that line all along the rpm range and tell you exactly how much power you made at each point along the rpm scale.
Old Jun 24, 2006 | 02:10 PM
jbrown's Avatar
Originally Posted by TrinaBabe
Yes the stock block will easily take that power all day long.
Ummm, not so much.
Will the car run reliably for a long time as long as proper care is taken and the car is not abused ... yes
Will it hold up just as long as a stock car ... nope
2x the horsepower = 2x the load on EVERY PART of the bottom end and a LOT of additional heat that must be dissipated by the radiator and oil cooler.
Bottom line is that, all things being equal, the 500hp motor will NOT last as long as the stock setup. It's just the laws of physics coming back to screw you over.
If you were to upgrade the radiator and oil cooler, as well as use a better oil, you might be able to achieve the same longevity, but I doubt it.
Edit: Don't get me wrong, the car will likely run fine for a very long time, it just won't be for as long as if it were still stock. Anybody ever seen a 500whp Evo with 100k miles on the original stock bottom end? I doubt it.
Old Jun 24, 2006 | 03:18 PM
Sean@Iveytune's Avatar
Fun fun car to drive.
Customer requests certain HP over normal, I will try my best to deliver, although there is a warning/disclaimer that goes along with that.
It's a reasonable risk to take and quite a few cars are over the 500hp power level (Stock bottom end) including mine that has been raced in over a standing mile with no issues.
Sean
Old Jun 24, 2006 | 03:32 PM
streetturbo's Avatar
Nice numbers! How much would you benefit from a stroker on that setup? I am thinking around 500-700rpm sooner spool and 15% wtq & 10% whp.
Here is a (motor) dyno from a 2.2 stroker with a similar setup(but with a gt3542r) that you have:
http://www.lancerregister.com/showth...2&pagenumber=1
Old Jun 24, 2006 | 06:41 PM
Oh so that isn't a chassis dyno? What kind of dyno?
I notice that isn't on 93 octane i see 99 octane?
hard to really make out a comparison.
Sean
Old Jun 24, 2006 | 06:49 PM
Sharkbite2000's Avatar
Pump and Meth very high numbers.
