Dyno results PeakBoost 3076 Dyno4mance
Old Jul 5, 2006 | 06:09 PM
  #46
nj1266's Avatar
From the chart boost seems to peak at 5300 rpm. That is way after the 3500-3700 rpm that a stock turbo peaks at. This is the boost peak on my stock Evo. It hits at full boost at 3500 and peaks at 3700 rpm.
Old Jul 12, 2006 | 09:14 AM
  #47
Toddevo 8's Avatar
from what I know the diffenence between the 3037 3071 and the 3076, is that the 3076 will have a little more top end power.
Old Jul 12, 2006 | 11:18 AM
  #48
PeakBoost's Avatar
Looking good sir.....Heres a pic of our new setup....PM me...
ps. NO the wg doesnt hit the radiator....
-anthony
Old Jul 13, 2006 | 10:04 AM
  #49
Toddevo 8's Avatar
turbo looks good ken, may want to go bigger later.
Old Jul 13, 2006 | 10:20 AM
  #50
Noize's Avatar
EvoM Administrator
Originally Posted by scorke
TedB/Smogrunner/Kjewer did you guys look at the links I provided in my post, compaired to other cars on the same dyno with the same turbo his car is substantially laggier, pointing out the fact that maybe the dyno does not skew spool as much as we think....Goto www.dyno4mance.com for yourself and take a peak at the mitsu graphs.
Scorke
There are two things to consider:
1) Recently, Andrew has started using bigger ramp rates for big turbo cars at Shiv's direction. I don't know if Chris did this while tuning Todd's car, but that will make it look laggier for sure. My car with a ramp rate of 100 will look like it spools 600rpm faster than when it is set at 115.
2) Todd's car has GIGANTIC Boyd Coddington chrome 18" wheels. They probably weigh like 75,000 lbs each. I've seen it several times on the dyno, but a heavy will will make the turbo come up slower (again due to weight and ramp rate). I think if he put stock wheels back on, the car would probably pick up 10whp.
Congrats, Todd! Your setup is awesome. I know you're happy. Great job tuning Chris. MyEvoVIII, thanks for sharing!
Seth
Old Jul 19, 2006 | 11:15 AM
  #51
Toddevo 8's Avatar
thanks noize, the wheels dont weigh as much as you think later.
tribe
26
Oct 28, 2008 08:23 PM
PeakBoost
West Region
Mar 2, 2006 08:52 AM
PeakBoost
49
Jan 23, 2006 04:06 PM
PeakBoost
20
Jan 20, 2006 10:52 AM
PeakBoost
32
Jan 16, 2006 02:13 PM
