Saikou kun catch can thread
Old May 12, 2006, 07:21 PM
denial's Avatar
Hey Saikou-kun, you should make a catch can with 2 separate chambers, each with their own baffling, entry/exit ports, and glass window! Kind of like a 2 in 1 deal
I've thought about fabbing one up myself but universal placement was the biggest problem. Plus, you'd have to run long lines from those places to a central location making it less than optimal.
Old May 14, 2006, 06:02 AM
EvoIXMR's Avatar
great idea, I would buy one. Easiest mid-point is either by the battery or by the motor mount on the other side. Its sort of mid-point, but not really. But, I would buy one if someone made it.
Saikou-kun - I sent you a PM!
Old May 14, 2006, 11:38 PM
Saikou_kun's Avatar
Dual chamber concept
I am toying with a 2 in 1 concept catch can design. I got a PM regarding a rectangular shaped one with separate compartments. I also tried to figure out a simpler universal version working with this idea. Here is the simplest design.
Still has a vapor snorkel, and stainless baffling material inside. No sight glass, and of course has a drain in the bottom of each section.
Both top fittings are the incoming line, and the side fittings are the exit.
Take a look
The size is compact, roughly 2" deep, 4" wide, and 5" tall, not including the fittings sticking out.
Old May 15, 2006, 07:53 AM
denial's Avatar
Take a look
Wow, that sucker is pretty compact. Looks great though You know, you could offset the sizes, make the PCV can larger in diameter while the intake can smaller and still keep it roughly the same dimensions. Just a thought...
Old May 15, 2006, 08:36 AM
Saikou_kun's Avatar
I can imagine making the PCV side longer for more volume. Good suggestion
Old May 15, 2006, 09:03 AM
CarFanatic's Avatar
ya, need something small and compact. Wish that didn't happen to the perrin, its a perfect fit right there for the pcv side. What could u stick in there to keep in from colapsing. Or maybe Saikou_kun could make one like teh perrin but out of aluminum and have it fasten in the same way.
ya, the ebay one was just a thought I thought it was funny with a magnetic oil drain aswell.
Old May 15, 2006, 09:17 AM
denial's Avatar
Well, the easiest suggestion would be to go to home depot and get you some PVC pipe that fits right into the catch can. However, I don't know if the plastic PVC pipe will hold up and not degrade given the conditions. A buddy of mine had done this some time ago and it seems to be fine, but a word of caution none the less. The best thing would be to find some thin-walled metal pipe equivalent to the ID of the can. No degrading issues there.
Old May 15, 2006, 10:34 AM
eling99's Avatar
i think ill just wait for Saikou Kun to make a 2 in 1 catch can!!!
Old May 15, 2006, 10:49 AM
CarFanatic's Avatar
I cant believe all these companys have catch cans out, and noneof them are designed correctly.
Old May 16, 2006, 05:01 AM
EvoIXMR's Avatar
Saikou_kun - Arent you supposed to be making a catch can? Get to work
Old May 16, 2006, 08:57 PM
Saikou_kun's Avatar
It's DONE! I am gonna try to post pics tonight. Maybe I will update my website too....
I figured I better put up a pic before I change my mind and not do it...
Old May 16, 2006, 09:23 PM
eling99's Avatar
Old May 17, 2006, 12:10 AM
Saikou_kun's Avatar
more pics before I got to...zzzzzzzZZZZZzzzz
Some pictures comparing the DC3 with the leading brand
...of course this is not the finished look, I wanna get them powder coated/painted
Attached Thumbnails Saikou kun catch can thread-dc3_firstshots_compare.jpg   Saikou kun catch can thread-dc3_firstshots_side.jpg   Saikou kun catch can thread-dc3_firstshots_welds.jpg
Old May 17, 2006, 12:15 AM
eling99's Avatar
powdercoat them black!!!
Old May 17, 2006, 12:26 AM
Saikou_kun's Avatar
Black it is.......now if only I can get some cool decals for these...
Quick Reply: Saikou kun catch can thread
