How Much Boost can my stock motor handle
No, high EGTs do not mean you're lean. In fact, you're more likely to get high EGTs when you're running rich. You cannot use EGT as a pseudo wideband. Also, wideband o2's don't have knock sensor - that's a separate tool.
Capt Kim, you do not use an EGT to determine what boost level is proper. You would need to log your timing to determine knock or use a knock sensor of some sort to determine knock counts.
Originally Posted by KILTERMAN
Lol.
I run 100 octane only and have the boost set at 26psi. It doesn't hold it normally holds near 24.5-25psi.
Detonation kills your motor. so using 91octane or 93 octane and pressing 26psi will kill your motor due to the detonation. Running high boost is fine with high octane fuel to combat detonation
do you understand what detonation is? not being a *****, im being serious.
If you're running 26.5psi on 93oct, then you're just begging for trouble. Please don't spread that info, because there may be other people who don't know any better and will try to do that. 26.5psi is the max I run on 93+alky. Doing that on straight 93 is just plain dumb.
yep it would be if i had knock/detonation (same damn thing) of any sort. besides no knock im currently (if i walked out and ran my car right now) at 25psi and my afrs are anywhere from 10.8-11.2 so i know what can safly be done. im not being an advocate and saying hey follow my lead. im just saying it can be done.
it was left rich because of the cold weather, we had it tuned to 26.5 psi after about 7-9 pulls on the dyno, so 2 guages readin afrs and close to heat soaked i pulled off the dyno turn the boost down a smidge and had it left a little rich.
http://www.turbobits.co.uk/acatalog/...egt_gauge.html
First paragraph. Your slippin warr. I think you are reading too many newbie threads.
Originally Posted by evo9-power
The answer is methanol and u can run 28-29 psi ease I run 28 non stop on my evo 9
The second time my car was custom tuned by Al at Vividracing we found out that the highest WHP and TQ numbers were obtained at 28PSI on my car.
We went above 28PSI and lost power and torque. We did the test on a Mustang Dyno. Raising the boost not always gives you more power specially when you max out the turbo.
You could modify the tuning to get more power at higher levels but them you compromise the reliability of the engine.
I am running 26-28psi on my MR but I use Methanol. I hope that help to answer your question.
Carlos
Carlos
What?
The hottest possible exhaust temperature is called peak EGT. If you lean the mixture at peak EGT (ie. reduce the fuel flow) the EGT drops and you are running lean of peak, or just LOP; if you enrich the mixture at peak EGT (ie. increase the fuel flow) the EGT also drops and you are running rich of peak, or ROP.
I hope that helps ya.
