How Much Boost can my stock motor handle
Old Jul 10, 2006 | 07:44 AM
  #46
travman's Avatar
on what fuel?
Old Jul 10, 2006 | 07:57 AM
  #47
KOEvo's Avatar
I'm not sure how this guys question was so hard for you guys to comprehend. .
The most boost on stock block i have heard of is 34.8 by TTP Engineering.
I am not sure how much cylender pressure the stock internals can hold in the end, but it would be nice if everyone would stock ***** footing around and actually answer the question.
Given A GOOD TUNE, what is the max boost that the stock internals can handle before letting go? I don't give a **** about "well does the car have the right gas?" "Does the car do this, or that?" WHO CARES he just wants to know a simple question that is very logical to ask.
Old Jul 12, 2006 | 03:11 PM
  #48
smjkxsnoopy's Avatar
now that we are mentioning boost levels...what boost do u guys recommend i should run when i get my car (evo 9) tuned (probably ecutek or dynoflash) on 93 octane with TBE, upper and lower ic piping, mbc, and drop in filter? im guessing 22?
Old Jul 12, 2006 | 03:42 PM
  #49
Gruppe-S's Avatar
I'm sure you can hold 35psi on the stock block (with no det) for a few passes since there will be very little cylinder wall expansion (closed deck), just gotta worry about lifting. That said I'd say more than a few passes bye bye rings! The stock piston/ rings jsut aren't designed for high boost applications. But at those pressures it'll take just one random det event to blow out the rings...
Old Jul 12, 2006 | 05:17 PM
  #50
Ted B's Avatar
"How much boost can the stock block handle" is not a very good question for several reasons, the most obvious being that running lots of boost with a small turbo creates a different set of problems than running the same with a large turbo.
Assuming one is speaking of a small turbo (e.g. 16G variant), applying lots of boost (e.g. 30+ psi) is only possible in the midrange, which essentially means that a substantial amount of torque will be generated. Torque refers to the amount of static force being applied with each piston stroke, which places a great deal of stress on those fragile connecting rod bolts, bearings, etc. Likewise, as torque is increased, the motor will have very little tolerance for detonation.
With a large turbo, torque isn't as much a problem as is heat produced from generating considerable amounts of hp. This heat must be dissipated by cast pistons, which weren't exactly intended for generating upwards of double the factory power rating.
There is no magic cutoff point where boost and power is concerned whereby the factory engine will suddenly let go. There are several potentially aggravating and mitigating factors that apply, such as accuracy of tuning, driver habits, etc., and so forth.
Old Jul 13, 2006 | 09:53 AM
  #51
TrinaBabe's Avatar
I think you got your answer about the boost thing....
Ted, I did want to say one thing about the motor though. I am pretty sure the reason the hard parts fail is due to high revs, knock or a ton of power at high revs. The G forces sustained at 9k on the rods is a HELL of alot more than at 7k.
And about the boost. I have hit well over 35psi a few times with mine. I normally run it close to 30psi. Stock engine/head with a GT35r.
Old Jul 13, 2006 | 01:18 PM
  #52
EMR8's Avatar
Originally Posted by Kwman
As long as you set your A/R to 17.9:1, run a 75 shot of nitrous, the motor should handle around 30 psi easy...on 87 octane. Its a great motor.
lol LOL
TCSTigersClaw
Mar 12, 2014 01:43 PM
rs03evo
Oct 26, 2010 02:15 PM
qu evox
Jan 29, 2009 08:24 AM
landis507
61
May 27, 2008 08:02 PM
fishbums
Apr 15, 2008 05:46 AM
