20g comparison
Originally Posted by nj1266
IMO, it is still deceptive to call it 20g. It is a 16g with a different compressor wheel. What else is changed aside from the wheel?
EVOlutionary
20g gives the ipmression that it is a bigger turbo for those who, as Ted mentioned, did not follow the sordid details of the entire "20g-6/20g-5" affair.
Mitsu calls the 9 and 05 8 turbos as "16g." Nowhere does mistu use 20g. Changing the compressor wheel, IMO, does not make a turbo 20g. It is more accurate to call it a 16g-9-5 or 16g-9-6. It is closer to the truth to use 16g than 20g. But vendors want to sell and the average buyer will not do enough research to get to the bottom of the nomenclature. Vendors have a vested interest in naming a 16g-9-5 or 16g-9-6 a 20g. It makes the turbo seems much different than the stock 9 turbo.
Ok, so let us say you had an 05 Evo VIII with the 16g and 10.5 hotside. You also had cams, cam gears, TBE, drop-in filter. The car puts down 350 hp on a dynojet. Would you switch to the so-called 20g-5? How much would you gain? Is it worth it? How would you before and after power band look like. Are you going to lose power down low to gain a smidgen up top?
Originally Posted by justchil
I give up. From now on I'm going to call my turbo a 18G just for confusion.
https://www.evolutionm.net/forums/sh...light=real+20g
Another guy says he has the real 20g. Good grief!!! How many 20gs are there?
Originally Posted by EVOlutionary
So AMS's GT37 really isn't a GT37 because GT37 isn't stamped on the side, right? Guess they should have called it a GT35Plus or something like that? And Buschur could have named his turbo the Buschur Racing 16Gwith20Gwheelandtrimmedturbine turbo. Personally, I think 20G sounds better. . . and makes more sense.
EVOlutionary
EVOlutionary
FYI
Why are you so hung up on this. We all understand and recognize that the 20g-9-5 and 20g-9-6 are 16g turbos with 20g wheels. Calling it a 16g-9-5 or 16g-9-6 makes no sense, because it doesn't say anything about the 20g wheel. It doesn't matter what the housing is or says - it's a 20g.
https://www.evolutionm.net/forums/sh...d.php?t=202727
FYI
The REAL 20g /////// 396awhp 343ft-lbs
That was on a Dynojet. The Buschur "20G" has made about 50whp and over 100wtq more than that the one time it was on a Dynojet, and has gone 11.2 or faster in the quarter mile. Not saying the "real 20g" can't match that, but I don't think it has yet. And the "real 20g" is quite a bit laggier than the BR 20G9-5, with spool-up closer to a 50trim.
EVOlutionary
Originally Posted by Steve@NoLimitmotors
actually Garret/Precision doesnt make a GT37R, only a non ball bearing Gt37. AMS made that name.
EVOlutionary
