20g comparison
Old Jul 5, 2006 | 12:38 PM
  #76
ExViTermini's Avatar
Originally Posted by EVOlutionary
The REAL 20g /////// 396awhp 343ft-lbs
That was on a Dynojet. The Buschur "20G" has made about 50whp and over 100wtq more than that the one time it was on a Dynojet, and has gone 11.2 or faster in the quarter mile. Not saying the "real 20g" can't match that, but I don't think it has yet. And the "real 20g" is quite a bit laggier than the BR 20G9-5, with spool-up closer to a 50trim.
EVOlutionary
The buschur 20g probably has made that power....on race fuel and high boost. Those numbers you see there were straight pump gas. I would be relatively happy with his setup as the curves are way better than any other stockstyel turbo I've seen yet.
Old Jul 5, 2006 | 12:44 PM
  #77
Warrtalon's Avatar
The curves are better than any stock turbo you've seen? No way, the torque was really low and didn't ramp up until much later than any stock turbo. Not sure what you meant by that comment. Yes, Ben's power was on pump gas, but it is laggy, costs a lot, and requires a custom manifold. When he does race gas, though, it will make some good power, I bet...probably more than the regular stock style 20g.
Old Jul 5, 2006 | 12:47 PM
  #78
sorry, I just realized that I was looking at the wrong dyno sheet
Anyway, yes there is a tad bit more lag....but overall it does not look that bad...I'd guess on the street you'd have very usable power by about 3400...? I like the fact that it can sustain the tq throughout the band though.
I love the way the stocker hits...but I'll be damned if it can hold the ****ing torque...its annoying...almost feels like blue ***** once you get to 3rd and 4th gear top end...
Old Jul 5, 2006 | 01:05 PM
  #79
EVOlutionary's Avatar
Yes, you are correct. So if the TT20G were tuned on race gas it would probably be right around where the BR20G9-5 has been power wise, maybe a little bit higher, but would be sacrificing a ton of the amazing torque ability of the BR unit.
As has been said in every corner of this forum, different people have different needs from their car. Some will take 20 more HP above 5000rpms, some want 40 more wtq between 2500 and 5000 rpms. What you want your car to be capable of will dictate what products you install. Personally, I like (and need for racing) huge low end torque to accellerate out of corners. When you have a Quaife front LSD and can spin 285/30/18 Kumho V710's coming out of a +1.0G corner - that is bliss.
EVOlutionary
Old Jul 5, 2006 | 01:13 PM
  #80
TTP Engineering's Avatar
Stock turbo Evos are hitting 11.7-11.9's @ 118 or so all the time these days. 11.97, 117mph is not impressive for a slower spooling TD06H.
Old Jul 5, 2006 | 01:16 PM
  #81
I contemplated the 20g for a long time. At the time I was looking for my next snail I had not seen good enough proven gains to justify spending the mula. My 50 trim has died(Piece of **** Innovative...stray away!!), and I have a TTR HP61 on the way...if I'm as unhappy with the spool on it as I think I might be, I will one of two things.
A) 2.3 stroker
B) 20G
I run alky so obviously I would be able to use it to its potential, just need to find some good low down on the graphs to see its real advantages.
Old Jul 5, 2006 | 01:17 PM
  #82
lol, I agree on the times, they're ****. But I've argued with him before..he can't drive
Old Jul 5, 2006 | 02:02 PM
  #83
TEXSRT4's Avatar
so where can i get my hands on one of these 20g-5's. i just need teh wheel. anyone have prices or availability???
Old Jul 5, 2006 | 02:18 PM
  #84
Warrtalon's Avatar
From Buschur only. He has previously listed all the prices for new one and for the conversion of an VIII w/9.8, VIII w/10.5, and IX.
Old Jul 5, 2006 | 08:01 PM
  #85
TEXSRT4's Avatar
thanks again warrtalon
Old Jul 24, 2006 | 11:16 AM
  #86
4TUN8's Avatar
With all respect to the above mentioned turbos, I pulled an 11.9 with a 1.84 60 foot.
This pass was made on pump, 22psi, 272 cams, stock front mount, and my horrible driving.
Once everything is dialed in with my alchy I won't be suprised to see 11.5 and lower.
Also maintaining boost is a lot easier with the real 20g, at 28psi I only see boost fall off by about one psi.
Plus the 20g-5 doesn't have a bad *** dyno video =)
Old Jul 24, 2006 | 11:19 AM
  #87
justchil's Avatar
You always forget to leave out you paid 2x as much (same cost as a 3065/35r kits)
I wish I had a local 1/4 track but all I have is 1/8
BTW I'm just messin with ya lol.. 20G is a great turbo to hold you over til you can get a big daddy turbo
Old Jul 24, 2006 | 12:42 PM
  #88
4TUN8's Avatar
I didn't pay anything for it =)
IMO 2950 for 80hp on pump gas = awsome
I'm hoping to see 440hp on alky.
Just wait until next year, I have a suprise for the evo world =)
Old Jul 24, 2006 | 03:28 PM
  #89
Dang it! I picked the wrong turbo . I want a bad *** dyno video . . . gotta add like 20whp!
EVOlutionary
Old Feb 5, 2007 | 11:35 PM
  #90
trinydex's Avatar
Originally Posted by justchil
I've had both (I have the 5 now) I wish I had some pics of the stock turbos off the 8's/9's
6blade:
5blade:
you have these pics still?
