Broke the sensor...which is it?
Old Jul 4, 2006 | 04:48 PM
S2Kstephen's Avatar
I had some problems with my car starting earlier today, and I noticed this sensor was 99% broken off, thus not getting a connection.
I'm guessing its a crank sensor, TPS, or something, but I need to know the same so I can pick up a new one at the dealer tomorrow. Its merely a black, plastic cylinder than sticks into what appears to be a pump of some sort. Has 1 10mm screw holding it into the "pump."
Which sensor is this circled:
Thx...and have a great 4th of July
Old Jul 4, 2006 | 04:59 PM
Spec'd's Avatar
Camshaft Position Sensor.
Old Jul 4, 2006 | 05:02 PM
S2Kstephen's Avatar
Makes sense...would that keep the car from complete turning over? It starts, but it acts like its not getting any spark. I also get a constant CEL, that pops right back on even after disconnecting the battery.
Is the CPS a part that a dealer would have to order?
Old Jul 4, 2006 | 05:08 PM
Sap12687's Avatar
Yes it will prevent the car from running.The dealer should stock it from around $55.
Old Jul 4, 2006 | 05:10 PM
Spec'd's Avatar
The symptoms you are describing sound like a CPS problem.
I read about members having intermitent missing problems before as a result.
I doubt that autozone, pepboys or equivlent will carry that part.
I usually buy my factory Mitsubishi parts from http://www.mitsubishiparts.net
Average 30% less than the dealer. I usually call them, get the part number,
than order from thier website.
They ship fast too.
Happy 4th of July btw ...
Old Jul 4, 2006 | 05:12 PM
hotrod2448's Avatar
Yes it will throw an instant CEL as soon as you start turning the engine over because it thinks the cam is not turning and the timing is off because it is still picking up a crank trigger signal.
Old Jul 4, 2006 | 05:15 PM
S2Kstephen's Avatar
Sweet...well thanks everyone!
I'll be grabbing another CPS and hittin the road again
Old Jul 5, 2006 | 09:48 PM
S2Kstephen's Avatar
I picked up the camshaft position sensor, installed it, cleared the code, and I'm back up and running again.
Thanks everyone!
Old Jul 5, 2006 | 10:17 PM
Spec'd's Avatar
Sweet.
DONNOD
Sep 28, 2016 06:32 PM
Dangerdave
Jun 4, 2015 06:56 PM
chrisw
May 18, 2010 07:51 AM
NYEvoguy
Jan 25, 2008 12:01 PM
Chino1
Nov 17, 2006 01:24 PM
