rhd to lhd
Old Feb 24, 2002 | 06:03 PM
death's Avatar
rhd to lhd
does any one know how much will it cost to convert a rhd evo 4 into lhd and what parts will be needed
thnx
Old Feb 24, 2002 | 09:02 PM
Lan Evo's Avatar
First off, welcome to the board.
To answer your question completely, you have to tell me whether you try to register this EVO IV, Or is it going to be a track car?
Old Feb 24, 2002 | 10:23 PM
FoxVR6's Avatar
Re: rhd to lhd
thnx
Just the thought of a project this big makes me cringe.
Old Feb 25, 2002 | 10:23 AM
death's Avatar
i will certinally register it we dont have a trck here
Old Feb 25, 2002 | 02:47 PM
Tachyon's Avatar
HELLA-expensive!
Old Feb 25, 2002 | 08:30 PM
GINO's Avatar
EVO 4
IT WILL COST YOU 6 TO 7 GRAND (USD)
YOU NEED STEERING RACK,FRONT CROSSMEMBER AXLE,
LHD PEDAL BOX ,ENGINE WIRING LOOM,DASHBOARD COMPLETE,
A GOOD ELECTRICIAN,ALOT OF PATIENCE,
Old Feb 25, 2002 | 08:35 PM
death's Avatar
jeez the car it self is worth 12 grand only
Old Feb 25, 2002 | 08:45 PM
Lan Evo's Avatar
And the next thing you know, you still can't register it because it doesn't have the 5-mph bumper, side door beam and maybe other "safety" features...
If you try to register it as kit car, you might have better luck...
You can use cheaper parts by getting used LHD Mirage parts EXCEPT the steering rack (EVO's steering rack is a quick one) so you can save a bunch. I'm not sure if you need new wiring harness or not....
Good luck.
Old Feb 25, 2002 | 08:47 PM
Lan Evo's Avatar
Oh, I thought you're in US, nevermind.....
Registering is not something I can answer for you here then...
Again, if you can get a hold of LHD Lancer/Mirage parts, you might be able to get this project to be cheaper...
Old Feb 26, 2002 | 02:29 PM
death's Avatar
i've been offered about $100 for complete job including a dashboard and the plastic in the armrest in which the mirror and the door lock switches go
they'll probably use the same steering rack and other stuff lots of welding i assume
u should come here man and see hundreds of converted toyota corrollas and sunny's some converted in 1993 and run fine till this moment
i think i should use a chepo car for conveting before fiddling with a evo
thnx
Old Feb 26, 2002 | 02:31 PM
death's Avatar
sorry $1000 not 100
Old Feb 26, 2002 | 09:39 PM
Lan Evo's Avatar
Slightly OT, but are those the Euro-spec Corolla and turbo sunny?
$1,000 sounds like a fair price to me, but, I say quality of work is more important than how much you spend. Make sure you get the right shop/mechanic to do this...
Good luck on owning the EVO.
Old Nov 19, 2002 | 08:19 AM
RedEvo6's Avatar
In Timeout
couldn't you just put qa mirage interior into the car itself? Thats waht soem guy did w/ a TME and made it LHD?
Old Nov 19, 2002 | 09:09 AM
Lan Evo's Avatar
It's more than just slapping all the interior bits. you will have to the LHD steering rack and you might have to get some extra wires for rewiring the dash-board
allan96817
25
Jul 17, 2025 06:00 PM
Grimgrak
Feb 18, 2017 11:16 PM
mb.8008
Apr 9, 2013 08:15 PM
ahvingsing
Jan 18, 2012 05:38 PM
ivanko
Feb 2, 2005 05:36 PM
