Tranny Problems
Old Jul 8, 2006 | 12:18 AM
icantdrive75's Avatar
Tranny Problems
So I went out to the track tonight. I just changed the fluid to BG Syncroshift II or whatever it's called. Changed the T-Case and rear diff fluid as well.
After a few runs, I pull into the pits. On the previous run I had never had any issue with the tranny making noises or loss of power. No lost gears. But once I stopped the car I could not get it back into gear. Once the car is moving everything shifts perfect. But at a stop it takes extreme force to get it into 1st. Stopped, in first, with the motor running. The car does not roll forward, and starts moving normally. Any ideas?
Old Jul 8, 2006 | 01:20 AM
elhalisf's Avatar
sounds like a problem in the hydrolic system. did you try adjusting the clutch pedal?
Old Jul 8, 2006 | 02:03 AM
mchuang's Avatar
I though the transmission was a cable. I see no slave cylinder?
elhalisf's Avatar
there is a slave cylinder at the trans and a master cylinder at the engine firewall.
Old Jul 8, 2006 | 02:04 AM
elhalisf's Avatar
the shifting is done thru cable
Old Jul 8, 2006 | 02:18 AM
ApexSilver06MR's Avatar
i think that ur muffler bearings are bad and ur blinker fluid is low. just playin. hopefully its not a sync problem in the tranny
Old Jul 8, 2006 | 07:26 AM
theoverachiever's Avatar
sounds like a bad presure plate to me....the clutch may not be completely disengaging
Old Jul 8, 2006 | 12:48 PM
The clutch is an exedy twin disc. I thought they were supposed to be indestructable! :P
I'm going to check the fluid levels. Then the adjustment. If that doesn't fix it then I'll pull the tranny and take a look at the clutch.
Old Jul 8, 2006 | 05:46 PM
Fixed it. Thanks for the help.
Old Jul 9, 2006 | 10:55 AM
evil mechanic's Avatar
hehehe
Old Jul 9, 2006 | 12:11 PM
djevoawhp's Avatar
what was the problem?????
Old Jul 9, 2006 | 03:47 PM
When I got the car the bolt on the clutch adjustment was finger tight. So it just kept pushing it self out of adjustment. Finally pushed it to far and the clutch wouldn't disengage. So just readjusted it.
