SBR GT35R Kit - Anyone getting over 500bhp??
Old Jul 10, 2006 | 08:01 AM
ez76's Avatar
Originally Posted by RichiW
Dont you think you should be running more than 441whp @ 27psi?? (its only 7whp more than me)
That dyno you posted was in ShootOut mode, which estimates engine horsepower, not wheel horsepower.
434 "ShootOut HP" is closer to 360whp on a DD in non-ShootOut mode, give or take depending on conditions.
Old Jul 10, 2006 | 08:08 AM
Ted B's Avatar
Ah yes, good observation. I was wondering how 98 RON (94 octane U.S.) could yield such a high result.
IF that estimation is correct (434whp in DD shootout mode ~= 360whp DJ), the result seems somewhat low for 24psi. Also, I would not expect high IAT to be an issue with a GT35R cruising along at 24 psi.
Advice - Run the dyno in normal mode and retry.
Old Jul 10, 2006 | 01:49 PM
RichiW's Avatar
The fuel is pump gas - 98 octane, its the best you get over here in the UK at the gas station.
As you have noticed the dyno was in shootout mode; in the UK all the tuners run in this mode, as it allows a better comparison between other dyno dynamic rollers at other establishments. I carnt see though how running in normal mode would alter anything car wise. It would still be working the engine as hard, boosting the same etc. so surely the end result would be the same; high IT and mixture running rich?
My mapper seemed to think theres a restriction in the exhaust side of things, which is causing a build up of heat, possibly cams? I'm running the Piper BP300's which only have 265 duration (217 @ 1mm) and 11.5mm lift. Even so, they are better than the OEM ones so i figure it must be something else.
Old Jul 10, 2006 | 01:57 PM
Flyin EVO 2's Avatar
If he's trapping 121 mph in the 1/4 then it is making around 420 whp. A stocker on race gas has made around 400 whp, and they trap around 117 mph. These are close to stock weight cars as well.
Old Jul 10, 2006 | 02:27 PM
Ted B's Avatar
Ok, 98 octane RON is about the equivalent of U.S. 93 octane pump premium (we measure ours differently). You're not going to be able to turn up the boost and get big power numbers with that fuel, period. Also, don't pay too much attention to claims of running greater boost on pump fuel - which does not necessarily lead to more power. Why? Because the ignition timing has to be retarded to withstand the high boost, which negates any potential power increase.
~420whp (Dynojet equivalent estimation) for a GT35R at 24psi is in the neighborhood of what's normal, but seems slightly on the low side. There are quite a few factors that affect this both directly and indirectly, but it's difficult to comment without knowing all the specifics of your setup.
I have an idea of what may be a contributing factor in your situation, but I have a few questions:
- What means of tuning are you using? You report running too rich, so what is the mixture (have a graph?), and what are you doing about it?
- What does your ignition table look like?
- You report high IAT. Have you checked your EGT?
- You should NOT have any surge issues. This is probably linked to your problem. Please furnish a boost graph (the one before you delayed the boost).
- Do you have those cams installed straight up - factory gears?
Old Jul 11, 2006 | 12:59 PM
RichiW's Avatar
Hi Ted,
I spoke to my mapper earlier today ( he was in his car on his way to map another car; he travels the world mapping rally cars for a profession). I asked him the questions and these are basically the answers he gave :
- What means of tuning are you using? You report running too rich, so what is the mixture (have a graph?), and what are you doing about it? The car is on a GEMs ECU ( same as an AEM), the mixture just started to go rich above 6000rpm - this could have been leaned out, but it shouldn't have been going rich in the first place at this point, so something somewhere else was wrong, especially with the IAT going high too.
- What does your ignition table look like? Ignition table is 1 or 2 degree's from det all the way
- You report high IAT. Have you checked your EGT? No, but the mixture was going rich, IAT rocketed and we weren't getting the air flow through the turbo - this lead to the presumption of very high EGT's, and all pointing to a restriction in the exhaust side of things being the cause.
- You should NOT have any surge issues. This is probably linked to your problem. Please furnish a boost graph (the one before you delayed the boost). I know he has graphs with the very bad surge showing - its in the same region as the graph on page one, only *very* wavy
- Do you have those cams installed straight up - factory gears? We did the initial mapping, calmed the surging down best we could, and then when we had got all we could from 0-0 timing, we tweaked the cams a few degree's this way and that to see if we could gain a few more bhp - which we did.
Everyone is saying that this turbo should not surge, which lead me to think that maybe the turbo was faulty, but another source says that if the turbo was faulty then there would be no way that it would produce anywhere near 400bhp at the flywheel like it is doing. Have to say though, this turbo doesn't sound as smooth when i turn the engine off as my old ball bearing converted OEM turbo, though i put this down to the GT35R having more mass and twin bearings.
Old Jul 11, 2006 | 02:34 PM
Ted B's Avatar
At a glance, it appears as though VE is rapidly decreasing above 6000rpm, which would account for the rich condition and may indirectly contribute to the high IAT. It may be due to something in the exhaust system that is restrictive, but there is no way to be certain.
The surging indicates that for whatever reason, the engine cannot mechanically accept enough air mass at that point. This is unusual for a GT35R, but with the shootout mode graph, I cannot really overlay your boost curve to mine to make a better determination.
We still don't know the actual cam timing - a few degrees 'this way and that' is sometimes significant.
Old Jul 11, 2006 | 02:47 PM
EFIxMR's Avatar
I think your timing is pretty low too. retarded ignition and fat afr = high egts.
just because your car is running fat with ignition timing low doesn't mean its running safe.
At WOT my 35R's AIT only went 10-12 degrees higher than ambient going thru 1-4 gears.
Old Jul 13, 2006 | 12:04 PM
RichiW's Avatar
Thanks for the feedback guys
My freind is having his Evo 9 mapped within the nxt couple of weeks; same everything apart from his is an Evo9 with the MIVEC. He's also using a different mapper.
I guess best bet now is to see how he gets on, and take it from there
Old May 15, 2007 | 04:40 AM
144mph's Avatar
Richi, any updates on your friends setup on the 9?
shiv@vishnu
88
Jul 18, 2017 02:56 PM
Octag3n
26
Oct 15, 2012 09:56 AM
rockmonkey69
European Forum
12
Aug 16, 2011 02:29 AM
kf6ytc
For Sale - Cars For Sale
15
Dec 17, 2008 10:41 PM
funnyclub
30
Sep 20, 2006 08:15 PM
