Thread size/pitch question
Old Jul 10, 2006 | 09:47 AM
M5150's Avatar
Does anyone know the thread size/pitch of the 17mm bolts going from the transfer case to the transmission?
Thanks,
Max Cudich
Old Jul 10, 2006 | 12:47 PM
boostedwrx's Avatar
Hmmm most of the metric JIS stuff is the same. If the bolt takes a 17mm socket, its probably an M12 JIS bolt and the thread is either 1.25 or 1.5.
Just FYI M10 takes a 14mm socket while M8 takes a 12mm socket
Check www.nutsandbolts.com for more info...
Old Jul 10, 2006 | 02:07 PM
althemean's Avatar
I believe the 14mm is the m10 1.25. definately the fine thread. I just bought some to mount my engine to the engine stand. I know thats not the t-case bolts you are after but maybe that will help narrow things down. Best bet is to go to the hardware store with the bolt, find the right size nut that fits it and then you will know. Or use a thread pitch gauge....
Old Jul 10, 2006 | 02:11 PM
boostedwrx's Avatar
Yes the 17mm he is looking for is JIS M12. The cool thing about Metric, they dont have 16million thread pitches like US Standard. If he buys one of each bolt (M12x1.25 or 1.5) He'll be set. However, I dont know how long of bolt he needs... usually JIS bolts are listed - M12x1.5x50. The 50 is the length of the bolt in millimeters. He'll probably want one that matches the exact length so he doesnt bottom anything out.. have to bust out the ruler!
Old Jul 11, 2006 | 09:23 AM
Steve_P's Avatar
For inch fasteners in the US, 99.9% of the time, there are two pitches, not 16 million, for fasteners: UNF (fine) and UNC (coarse). Metric often has three thread pitches for one diameter so I don't see how that's better. Also, I don't think you will find anything but a coarse thread metric bolt at a local hardware store.
Old Jul 11, 2006 | 09:56 AM
boostedwrx's Avatar
Yea all the local hardware stores dont have anything metric. He'll have to order his bolt from the factory most likely. Nuts and bolts.com doesnt have what he wants, I just looked.
In terms of JIS bolts though, I rarely see anything different from 1.25 or 1.5 pitch.
Old Jul 11, 2006 | 11:47 AM
M5150's Avatar
Thanks, that was answer I was looking for!
Old Jul 12, 2006 | 04:23 PM
kjewer1's Avatar
Every single bolt on the DSMs was 1.25 pitch. I've yet to find otherwise on the EVO. I am lucky enough to have a local hardware store that stocks the 1.25 pitch in all common sizes (M8-M12), but when I can't find it there I usually go to www.mcmaster.com.
jakgal04
Jan 4, 2017 08:49 PM
3bar_dc2
Apr 12, 2016 07:13 PM
hiner005
Nov 20, 2013 12:53 PM
Barse
10
Nov 9, 2008 02:20 PM
huevosrancheros
Dec 29, 2007 06:58 PM
