popping from transmission
it seems like im having endless problems with my evo but i'll try to solve one at a time and hope someone can give me some advices... this started yesterday actually... whenever let my clutch out and give it some gas from a stop... i hear and feel "pop pop" from under my foot.... and today when im coming to a stoplight for a full stop... i feel and hear "pop" under my foot when braking... i don't exactly know what this is but it doesn't sound good...hope someone can help me out....Mitsubishi void my warranty already so im on my own... im apparently broke right now and i got dynoflash end of this month so i want to make sure everything is in working order...
thanks
thanks
Dude I am also experiencing the same exact symtons....does this also happen when you are comimg to a stop, especially on bumpy surfaces? I just had an ACT clutch installed not even 2000 miles ago so I hope it's nothing too major. If anybody has experience please help us out. Thanks
J8 dailo why would you think it's the clutch? c'mon guys I searched and couldn't find any info so can someone share or anyone had this problem.......thanks. I wa thinking more like a wheel bearing or strut, etc.......
I was having the same problem with my car, but It turned out that the plastic in the wheel wheel had come loose. It kept making that popping sound, and I could feel it right under my feet.
what plastic? i checked and found nothing...it really sounds internal..... i notice when i hit the brake somewhat hard...it pops and whenever i go over a bump..it pops...
I do not think it's the wheel bearing. When a wheel bearing goes bad you will hear vibrations when you turn right or left. I've had one of my bearings go bad and that's what happened.
J8 dailo I checked under my car right....found plastic loose from the under carriage in the front cause I had taken mine out. Also, you have bolts that attach the tie bars to the car, be sure you are not missing any those bolts which was causing the popping noise in my 8. sorta sounded like the enjine was moving like a knocking sound but once I replaced two missing bolts on the tie bar bracket the noise stopped! You will need to get under the car btw.... Good luck!
