evo 9 turbo installed in my '05 evo 8....
Old Jul 14, 2006 | 07:04 PM
whitersevo's Avatar
nice set up .... looking forward doing that same thing....
Old Jul 15, 2006 | 12:38 AM
freshevo8's Avatar
bigric, that like me asking al for his cable, see where i'm coming from?
Old Jul 15, 2006 | 05:55 AM
TURBODAWG's Avatar
Datalog your wideband on race gas today at high boost and send me the file. I will help you get the tune dialed in better for the track tomorrow. It will be hot tomorrow and humid, so I dont think even with a perfect tune that the car will run its best. You will probably have to wait to a cooler night to get that 11.8 ... But it wouldnt hurt to get the tuned dialed in better.
Brian
Old Jul 15, 2006 | 06:13 AM
bigric09's Avatar
translation of i need your cable = i need you to flash my ecu... but i either way i didnt realize we were cool like you and al, thought we were a little different
Old Jul 15, 2006 | 10:09 AM
freshevo8's Avatar
Brian
thanks brian. i'll try and get that done today.
Old Jul 16, 2006 | 12:37 PM
Turbotsiawd96's Avatar
the evo 9 turbo is so impressive. I got an evo8 and threw on the evo9 20g 6 blade i never had a chance to get it dyno tuned due to some catastrophic problems but....it just pulled harder and felt like it wouldnt stop pulling. Im now treading in my 8 due to the problems and getting the nine in a couple of weeks and gonna start of new but im gonna sell the 20g turbo
Old Jul 16, 2006 | 06:54 PM
bigric09's Avatar
matt where did you post the madness ? off topic i bet lol
Old Jul 22, 2006 | 06:01 PM
Jeff_Jeske's Avatar
Bump for an update on this.....I see you got your 11.8 but I am curious how your tune changed from the 8 to the 9 turbo.
Also did loosening the wastegate arm help recover spool as well as reduce boost creep?
Old Jul 26, 2006 | 12:31 PM
freshevo8's Avatar
i kept the same custom street tune installed when i changed the turbo and exhaust manifold. no changes were made to the ecu for pump gas. all it did was lean the afr's out a little bit from 10.4 afr to a 10.7-10.8 afr. the car runs great on 93oct and 22psi. i didn't loosen the wastegate arm yet because the boost creep seemed to work its way out for the most part. it creeps maybe 1/2 psi on the boost gauge. not sure why the boost creep went away but it did and the car is running great!
Old Jul 26, 2006 | 12:57 PM
Haehl's Avatar
Do you mind sharing what your mods are? besides the obvious new turbo...
Old Jul 26, 2006 | 02:41 PM
freshevo8's Avatar
basically equivalent to buschur stage 4, plus 9 turbo and br ported and coated exhaust manifold.
rotaryboxer
12
Feb 26, 2016 02:18 PM
deuce329
60
Feb 6, 2009 08:01 PM
c900t16
Lancer Aftermarket Forced Induction Tech
11
Nov 21, 2007 07:06 PM
hamflex
Feb 22, 2007 08:53 PM
wheredafucrwe
Oct 26, 2004 12:10 AM
